Legacy Posted March 1, 2010 Share Posted March 1, 2010 I have some models whose paint job I literally cant stand. How the devil to I get the paint off? So far nail polish remover and paint thinner have not worked. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/ Share on other sites More sharing options...
hendrik Posted March 1, 2010 Share Posted March 1, 2010 first of all this belongs in the painting/conversion section second: trey brake oil. still, just go over to the painting section, it's filled with topics conserning this Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301307 Share on other sites More sharing options...
rodgers37 Posted March 1, 2010 Share Posted March 1, 2010 Dettol Works really well.... Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301319 Share on other sites More sharing options...
Legacy Posted March 1, 2010 Author Share Posted March 1, 2010 thanks. my bad for not reading the painting section. Chalk it up to noobishness. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301322 Share on other sites More sharing options...
Sulfurious Posted March 1, 2010 Share Posted March 1, 2010 Purple Power from Wal-Mart. Â It's an engine degreaser you can find in the automotive department. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301347 Share on other sites More sharing options...
jester262 Posted March 1, 2010 Share Posted March 1, 2010 simple green Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301355 Share on other sites More sharing options...
Spazmonkey Posted March 1, 2010 Share Posted March 1, 2010 Simple Green or Break fluid, Â Break fluid works best, but you need to look for a non corrosive type, and wear gloves... and do it some where there is fresh air... Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301362 Share on other sites More sharing options...
Warhorse47 Posted March 1, 2010 Share Posted March 1, 2010 Pine Sol works very well. Let em sit in it a day or two, and use an old toothbrush. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301374 Share on other sites More sharing options...
stvnpc Posted March 2, 2010 Share Posted March 2, 2010 One product that I found that worked like magic was Simple Green. You can find it at Walmart, Home Depot. Lowes, Grocery Store. Soak them for about 30 minutes (test to see if the paint is coming off) and use a tooth brush on them to get the paint off. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301574 Share on other sites More sharing options...
Grey Mage Posted March 2, 2010 Share Posted March 2, 2010 Metal or plastic? Got much time? Â I find that a peice of terry cloth and alot of rubbing will get the paint off a plastic mini, and then a spunge and a tooth cleaner to get the rest out of the crevaces. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301632 Share on other sites More sharing options...
Logan230 Posted March 2, 2010 Share Posted March 2, 2010 +1 for Simple Green! good stuff, that or break fluid. Outside of the carefulness about working with brake fluid, Simple Green is uber-concentrated. according to the instructions you are supposed to cut it 10:1 with water. found that out when i was cleaning mold off of my girl's window, we got high :D Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301680 Share on other sites More sharing options...
Arraken Posted March 2, 2010 Share Posted March 2, 2010 Simple Green for plastic. Metal you can use a paint stripper or brake fluid. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301720 Share on other sites More sharing options...
styx Posted March 2, 2010 Share Posted March 2, 2010 I use Simple Green or Wesely's Bleach White (tire cleaner), soak 24 hours, scrub with tooth bursh rinse the brush with water as you work. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2301984 Share on other sites More sharing options...
Taeken Posted March 2, 2010 Share Posted March 2, 2010 Purple Power from Wal-Mart. It's an engine degreaser you can find in the automotive department.   Totally. A couple days soaking then 90% comes off with water. Add in a little tooth brush scrubbin and its done! I've used it on both metal and plastic. Add in the fact that a gallon only runs 3-4$ its really nice. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2302063 Share on other sites More sharing options...
Raulmichile Posted March 2, 2010 Share Posted March 2, 2010 Thinner por metals, but DON'T USE WITH PLASTICS! Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2302113 Share on other sites More sharing options...
TheLoneWolf Posted March 3, 2010 Share Posted March 3, 2010 I vote for dettol, as dettol is good for both plastic and metal and its easier to use.... :lol: Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2302745 Share on other sites More sharing options...
CainTheHunter Posted March 3, 2010 Share Posted March 3, 2010 Pure acetone - great for metals. I've found it useful for plastics as well, but you must be very careful - don't let them soak in it, because they will start melting in a minute. Instead I am using an acetone-soaked piece of cotton, which I apply for a short period of time to the portion of plastic mini which I want to strip from paint. It is important to wash the plastic mini under the water after each time You've applied the acetone. With metals, I simply leave them soaking for a day. Link to comment https://bolterandchainsword.com/topic/193708-removing-the-paint/#findComment-2302749 Share on other sites More sharing options...
