SpecialIssue Posted March 9, 2010 Share Posted March 9, 2010 Right- my main opponents are 'nids and Tau. I've got Scouts with a LSS, and envision this units used in two roles: vs. Tau: alpha strike, using the Scout move and the LSS's fast movement/flatout in 1st turn to reach Tau lines for CC to either tie up his Broadsides/pathfinders/firewarriors, or target his Hammerhead with sergs' combi-melta then meltabomb/powerfist/krak grenade it in CC. vs. 'nids: harrasment, cleaner, last turn objective grabber, anti-lictor, LSS interferes with sporepod deploment. Drive-by shootings. So, question is- give the scouts shotguns, or bolt pistol-CCWs; and for the LSS either multi-melta or heavy flamer. Does the BS3 for the melta handicap it too much? Can five scouts with shotguns hold their own against 10 firewarriors or two broadsides? Link to comment Share on other sites More sharing options...
rat of vengence Posted March 9, 2010 Share Posted March 9, 2010 Heavy flamer all the way mate definitely. It can't miss. I wouldn't shoot Tau with shotties, they may fail a leadership check and leave you stranded with no assault. Get in and carve them up, but try to engage 2 squads; one probably won't break and will leave you free of being shot to bits. There is another thread about LSS/scouts here, have a peek :) RoV Link to comment Share on other sites More sharing options...
greatcrusade08 Posted March 9, 2010 Share Posted March 9, 2010 Heavy flamer all the way mate definitely. It can't miss. I wouldn't shoot Tau with shotties, they may fail a leadership check and leave you stranded with no assault. Get in and carve them up, but try to engage 2 squads; one probably won't break and will leave you free of being shot to bits. There is another thread about LSS/scouts here, have a peek :) RoV Tau are one of the best opponents for scouts, they fold like little babies in cc and scouts can infiltrate/outflank and get first turn assaults. If you take ccws on the heavy flamer LSS scouts (i use combi-flamer and fist too) and charge two units then the ld modifier from the cerberus launchers will affect both units. your likely to run both off the table ;) Link to comment Share on other sites More sharing options...
