Shooting From Rhino
jjfelber
As far as I understand it a rhino has two fire points for those riding in the vehicle to fire weapons from.
I think that if you are shooting a psychic attack which does not require line of sight then this could be used in addition to the two normal shots from those mounted in the vehicle.
You can only fire from a tank if it moves less than six in any case.
Defensive weapons (str4 or less weapons that are mounted on the vehicle) can always fire.
Hope this helps and that I am not wrong.
After all that to put it simply
Yes
Yes
No
Yes
Yes
No
Can I use Psychic powers from a Rhino,
If it doesn't move = yes. you can shoot 2 things. your priest and any other weapon.
If it moves <6 Inches = yes. you can shoot one thing. so your priest can.
If it moves more then >6 = nope.
Can a single model shoot a weapon from a rhino
If it doesn't move
If it doesn't move
Sorry no rulebook with me.
There are always exceptions to rules and in the case of psychic powers the ultimate answer is "it depends"
A RP can't cast living lightning if in a rhino that moved 12" but he could cast tempest's wrath or storm caller (not defined as psychic shooting attacks and would have occurred at the beginning of the turn)
