The fighting iron priest?
Im toying with the idea of an Iron preist on a bike or thunder wolf accompanied by cyberwolves.
But im wondering about him being on a bike and the wolves being beasts, do they limit each others movement and charge ranges? i really dont want to buy another thunderwolf so i might make a custom bike counts as.
have any of you used this unit and if so what are your thoughts on it? thanks.
https://bolterandchainsword.com/topic/195391-the-fighting-iron-priest/
The old codex FAQ used to say you can move at bike speed with 2 fenrisian wolves, but could not turbo boost. Those days are gone, though. We must refer to the rule book, so strictly, you must move at the speed of the slowest model.
1. So movement... Lowest speed is 6 inches - the cybewolves hold them back.
2. Fleet? No! Iron Priest lacks fleet. Can't fleet.
3. Assault? 6 again, the iron priest.
4. Turbo boosting? Forget it. The cyberwolves can't.
The bike is a colossal waste of points if you want the cybewolves.
I'm working on a TW mounted Iron Priest atm. Going with a more cyborg than not wolf as I figure any wolf that will hang with an IP is going to be very mechanical. Most likely a mangled TW that the IP took off the battle field then replaced / modified what was missing and or broken.
