Adding a different feel to scouts
Meatman
http://i186.photobucket.com/albums/x267/mightymwatt/100_0602.jpg
I got a little bored of the standard cloaked snipers, so I decided to try something a little different.
You know the left over body in the sniper scout box that has a sniper rifle that goes with it? Well, you have no extra legs to assemble it into a proper scout. You get heads spare so that's not a problem.
Essentially, this is a cheap and good looking way to get an extra sniper.
Using a cheap foliage substitute (I got mine from my local store called Model Junction for about £1.49) such as this:
http://i186.photobucket.com/albums/x267/mightymwatt/100_0609.jpg
http://i186.photobucket.com/albums/x267/mightymwatt/100_0616.jpg
It literally just pulls apart in your hand so you can use as little or much as you need.
You can easily make a bush of sorts for your little leg-less scout to hide in.
I wanted mine to look like he was standing, about to move out to take a shot, so I mounted him on piece of foam I had in my garage but you can chose what you like to increase his height. No-one will see as the foliage will hide it.
Now on to the assembling!
Leave plenty of time to dry between dry between stages.
Stage 1: Using a glue suitable for your mounting, glue the mounting to the base (I used PVA glue)
Stage 2: Glue your scout, pre assembled (and primed if you are going to spray paint it), to the top of your mounting
Stage 3: Break off your foliage into pieces and use PVA to glue around the basing, and your scout. Make him as hidden as you want.
Stage 4: Go back over with watered down PVA to ensure the foliage stays glued to your scout and the mounting.
Stage 5: Paint!
Some more photos:
http://i186.photobucket.com/albums/x267/mightymwatt/100_0603.jpg
http://i186.photobucket.com/albums/x267/mightymwatt/100_0604.jpg
Hope you've enjoyed!
https://bolterandchainsword.com/topic/195451-adding-a-different-feel-to-scouts/
  • 3 weeks later...
Absolutely fantastic! Really appeals to those of us who want the most from a Boxed Set! Having been drawing in by Chaos - ''Do You Hear The Voices Too? !!!'' - I won't really have much opportunity to field Scouts. Unless - exclusively for Friendly Matches - I Model some Traitor Scouts, use the Loyalist Rules, and see what happens! Oooh, so tempting!
Tropicana
  • 4 weeks later...
Seen something like that in an Apocalypse game. The massive Nid army advanced, leaving 5 Ultramarine Scouts behind to snag one of the rear objectives... Everyone thought they were terrain until the guy split them up and moved them.
Undeniably looks cool though.
  • 1 month later...
