Token Posted March 24, 2010 Share Posted March 24, 2010 Does acute senses work against the gray knights stealth thingy? Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/ Share on other sites More sharing options...
breng77 Posted March 24, 2010 Share Posted March 24, 2010 no as it only works against night fight. Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/#findComment-2331815 Share on other sites More sharing options...
Token Posted March 24, 2010 Author Share Posted March 24, 2010 Ok, thanks. Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/#findComment-2331833 Share on other sites More sharing options...
Vassakov Posted March 24, 2010 Share Posted March 24, 2010 Having just checked, Breng is now correct. It used to, as we could "smell the incense from a mile off :) " However, looks like they've changed this for 5th :) Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/#findComment-2331951 Share on other sites More sharing options...
Token Posted March 24, 2010 Author Share Posted March 24, 2010 Hm, what would happen if wolves fought the knights in the dark? Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/#findComment-2331984 Share on other sites More sharing options...
CainTheHunter Posted March 24, 2010 Share Posted March 24, 2010 Hm, what would happen if wolves fought the knights in the dark? You meaning, Grey Hunters battling Grey Knights? :D "All cats are grey in the dark..." Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/#findComment-2332012 Share on other sites More sharing options...
stinkenheim Posted March 24, 2010 Share Posted March 24, 2010 night fight takes priority as it is the shorter distance (iirc) and you can re-roll the distance you can 'see' thans to acute senses. but normally no, the shrouding isn't affected by acute senses. Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/#findComment-2332206 Share on other sites More sharing options...
Valerian Posted March 25, 2010 Share Posted March 25, 2010 night fight takes priority as it is the shorter distance (iirc) and you can re-roll the distance you can 'see' thans to acute senses.but normally no, the shrouding isn't affected by acute senses. Actually, I believe that both would/should apply. First, Space Wolves roll to see target according to Night Fighting rule. If target is not visible, Space Wolves unit may reroll check due to Acute Senses USR. Next, Space Wolves have to make another, single, seperate roll to account for The Shrouding - which has nothing to do with Night Fighting whatsoever. Valerian Link to comment https://bolterandchainsword.com/topic/195791-acute-senses-and-gray-knights/#findComment-2333477 Share on other sites More sharing options...
