The Aquila Project mk II - Hellkite Dos
Some of the folk here might remember that Space Marine skimmer conversion I did a year or so ago, and I've decided to add another model I can shamelessly use for Apocalypse games. I worked on this in parallel with my LPC Vow, with the leftover plasticard I had, and spare parts.
I plan to use this as an allied Stormraven, so the construction is a wee bit different from the previous Hellkite, in that there will be a place to hang a Dreadnought in the rear, between the wings and underneath the (as yet) unconstructed main engine housing.
All in all a good start, I think.
  • 2 weeks later...
UPDATE 04/08/2010:
While this is a long-term project of mine, it doesn't mean I'm not actually doing anything on it. I recently finished the engine housing on it, and while it seems small, one needs to remember the two other engines I attached under each wing.
I used Devilfish engines, because I wanted to mostly preserve the skimmer-ish aesthetic. Besides, everyone else is using the turbines of the Valkyrie kit, so might as well be different eh?
It easily has more mass now than a Land Raider, and I haven't even started on the weapons! This one will eventually get a dorsal-mounted twin-linked Lascannon, Hurricane Bolter sponsons, as well as missiles under each wing.
The grunt-work with the plasticard and modeling putty is still fairly obvious at this point, but it won't be too noticeable once I hit it with the silver primer, ahaha.
And that's it for now.
I like where your going with this...
Had the same idea about scratch building the front from a rhino but found it too small, so i went with this.
http://www.dakkadakka.com/s/i/at/at2/2010/4/8/e989fffb4c1445a8d414ac8c130a8b5a_5626.jpg
Great model by the way!
  • 1 year later...
A slight update on an old project... Actually I finished this a LONG time ago, though I never got around to taking a picture of it. Well, no more! Here are the pictures, as well as a comparison with the previous conversion I made.
And the comparison with the new plastic Venerable dread, my old Hellkite, and the new conversion:
And there you have it. Done, and done.
