stupidn question
Niiai
well it says you may chose one o the following, then states you replace the storm bolter with all the heavy weapons except the CML. so even if you could choose two of the same weapons you don't have two storm bolters to swap out so the only thing you could even try and get would be two CML... which obviously would be more than the one your allowed :D
well it says you may chose one o the following, then states you replace the storm bolter with all the heavy weapons except the CML. so even if you could choose two of the same weapons you don't have two storm bolters to swap out so the only thing you could even try and get would be two CML... which obviously would be more than the one your allowed ;)
Well actually no - if You start with the CML. You first pick CML, because You don't swap out anything, and then You have SB, PW and CML, which technically allows You to swap the SB, which You still have, for AC or HF. But I don't think that's whtat the rules imply.
Actually, the main problem with that setup is that second heavy weapon, that youve spent so many points to unlock, couldnt be fired at the same time as the first heavy weapon- because infantry, unlike say dreads, can only fire one weapon a turn. The CML gives an exception to this- in the case of stormbolters, but not in the case of assault cannons, heavy flamers, or another CML.
