BOBMAKENZIE Posted March 30, 2010 Author Share Posted March 30, 2010 Thats 140 Dollars in kit alone I can see there @_@ Not that its bad just holy jeeze I did one from a second hand raider and a pod for about 50 Dude, they want your cash, you really think that they would do a workshop using a "cheap" conversion? Having seen the workshops my local GW runs I can say yes they do. They are pushing product but it doesnt mean they have to really push something quite so expensive. And Im not saying that as a future employee. :cuss That conversion is The Wings of a Valk with the back crew compartement Attacked to an angled and cut up walls of a raider (Crusader) Leaving the interior layer off. Assault Cannons are Replaced with the Cockpit piece from Valk. HB Razor turret mounted back on the Top of the Raider. And assault cannons on the underside. Its pretty simple over all. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2340394 Share on other sites More sharing options...
Demoulius Posted March 30, 2010 Share Posted March 30, 2010 Thats 140 Dollars in kit alone I can see there @_@ Not that its bad just holy jeeze I did one from a second hand raider and a pod for about 50 Dude, they want your cash, you really think that they would do a workshop using a "cheap" conversion? Having seen the workshops my local GW runs I can say yes they do. They are pushing product but it doesnt mean they have to really push something quite so expensive. And Im not saying that as a future employee. ;) That conversion is The Wings of a Valk with the back crew compartement Attacked to an angled and cut up walls of a raider (Crusader) Leaving the interior layer off. Assault Cannons are Replaced with the Cockpit piece from Valk. HB Razor turret mounted back on the Top of the Raider. And assault cannons on the underside. Its pretty simple over all. seems pretty spot on... incidentily i was hyped up when i saw the photo, posted it and went back to reading how much it would set me back...100 euros....OUCH!! workshop gets you a valkyrie and a landraider and the workshop. il have to check out the codex first if il even use one of these first befgore i commit that kind of money to something... building stuff like that is fun and all but if im not gonna use it....i dont know :tu: Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2340440 Share on other sites More sharing options...
Sanguinarian Posted March 31, 2010 Share Posted March 31, 2010 That's a load of dough AND points that I plan on sinking into my Death Company Storm Raven!!! I like the LR+Valk build best and plan on doing a similar build, but I'd like to find a way to allow my LR© to detach from the "wings" in case I want to use it as a separate LR©. In any regard it will definitely be optional mode of transport for my DC as I think they should get all the new toys first. Sane warriors may be a little too concerned with maintaining the pristine paintjobs, being that we are such artisans. :tu: So a new LRC & Valkyrie will run me $116 USD, and I'll use my existing 10 DC, Reclusiarch Chaplain & DC Dread (CCW + AC). That'll give me ~ 700pts of insanity to run at the enemies of The Angel. ;) Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2340461 Share on other sites More sharing options...
BOBMAKENZIE Posted March 31, 2010 Author Share Posted March 31, 2010 That's a load of dough AND points that I plan on sinking into my Death Company Storm Raven!!! I like the LR+Valk build best and plan on doing a similar build, but I'd like to find a way to allow my LR© to detach from the "wings" in case I want to use it as a separate LR©. In any regard it will definitely be optional mode of transport for my DC as I think they should get all the new toys first. Sane warriors may be a little too concerned with maintaining the pristine paintjobs, being that we are such artisans. :( You are going to run into size issues with the full on LR attached to a valk hull. Its also going to be awkward mounting it with the tracks on as well. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2340482 Share on other sites More sharing options...
Alexos Posted March 31, 2010 Share Posted March 31, 2010 Well, looking at that stormraven, you have to cut the side doors off of the Land raider, then take that and cut it in halph, glue the front and rear together, then put all of that onto the front end of a Valkyrie. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2340504 Share on other sites More sharing options...
Sanguinarian Posted March 31, 2010 Share Posted March 31, 2010 That's a load of dough AND points that I plan on sinking into my Death Company Storm Raven!!! I like the LR+Valk build best and plan on doing a similar build, but I'd like to find a way to allow my LR[C] to detach from the "wings" in case I want to use it as a separate LR[C].In any regard it will definitely be optional mode of transport for my DC as I think they should get all the new toys first. Sane warriors may be a little too concerned with maintaining the pristine paintjobs, being that we are such artisans. :woot: You are going to run into size issues with the full on LR attached to a valk hull. Its also going to be awkward mounting it with the tracks on as well. Yeh, I did some sketches of trying to keep the LR intact and just add the Valk....screw it...Dante's Flying Land Raider is good enough for me!!! Besides since our LRs can DS now, there aren't many advantages to an SR? Can you assault out of it after moving flat out? Don't think so. LR's armour is 14; SR is only 13. Me thinks. LRC can hold 15 DC; SR can hold 12+Dread. Hmmm...??? That's probably the only advantage, aside from movement & +1 weapon. Are these enough though? LRC is cheaper than the DIY SR, especially since I'd want 3 of either. That's the deal-breaker!!! Can someone metagame 3 LRCs filled with 3x15 DC & Astorath, of course! vs. 3 SRs filled with 3x12 DC + 3 DC Furiosos & Astorath? Or would it come down to the vehicles themselves? LRC vs. SR sitting 12" from each other? Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2340659 Share on other sites More sharing options...
BOBMAKENZIE Posted March 31, 2010 Author Share Posted March 31, 2010 Can you assault out of it after moving flat out? Don't think so. LR's armour is 14; SR is only 13. Me thinks. LRC can hold 15 DC; SR can hold 12+Dread. Hmmm...??? That's probably the only advantage, aside from movement & +1 weapon. Are these enough though? LRC is cheaper than the DIY SR, especially since I'd want 3 of either. That's the deal-breaker!!! Can someone metagame 3 LRCs filled with 3x15 DC & Astorath, of course! vs. 3 SRs filled with 3x12 DC + 3 DC Furiosos & Astorath? Or would it come down to the vehicles themselves? LRC vs. SR sitting 12" from each other? No 12 Kinda Better Better Guns, Locator Beacon, options for the speed. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2341375 Share on other sites More sharing options...
Vel'Cona Posted March 31, 2010 Share Posted March 31, 2010 Actually, that conversion/kitbash that Demoulius posted is pretty much the best and most accurate concept I've seen yet for a Storm Raven. It looks like a mini-Thawk, which is exactly how I envisioned the SR. It's actually not that insane to convert, either; it's essentially a LRC/LRR box with the hull chopped in half, and the wings, engine, and tail of a Valkyrie cut to fit. All said and done, about 100 bucks. Pretty fair deal for an advanced kitbash, especially if you want something that isn't a LR with wings. Though, to be fair, the LR w/ wings is funny as heck. It looks awful, but it's great for lulz. :D Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2341461 Share on other sites More sharing options...
Demoulius Posted March 31, 2010 Share Posted March 31, 2010 Actually, that conversion/kitbash that Demoulius posted is pretty much the best and most accurate concept I've seen yet for a Storm Raven. It looks like a mini-Thawk, which is exactly how I envisioned the SR. It's actually not that insane to convert, either; it's essentially a LRC/LRR box with the hull chopped in half, and the wings, engine, and tail of a Valkyrie cut to fit. All said and done, about 100 bucks. Pretty fair deal for an advanced kitbash, especially if you want something that isn't a LR with wings. Though, to be fair, the LR w/ wings is funny as heck. It looks awful, but it's great for lulz. ;) ye the lulzfactor is high :unsure: tommorow im going to the GW to check out the dex. 12+dread sounds nice! but jumppack models count as 2 models right? Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2341557 Share on other sites More sharing options...
Dunamis Posted April 4, 2010 Share Posted April 4, 2010 I don't know if this is still a tactica thread or a how to make thread or both. So I'll throw in both: Tactica: DC Dread + 10 DC (Fist) w/ Lemmy If my rules were correct this got me a dual charge with the Fleet Dread having a charge range of 24-29" off the Raven even if it comes in from reserves (12" Raven move + 1.99" disembark +3" base length +1-6" fleet + 6" Charge) letting you roll up on a juicy target with the Lemmy and the Boys and at the same time throw the Dread at whatever is waiting around to countercharge. (I have this image in my head of the Raven pilot whipping the tail of the Raven around and hitting the release on the Dread Grapples at the same time to literally sling the Dread into his target) Admittedly the Jump pack Lemmy will be slowed down by his earthbound charges but I think his I6(7) putts his power weapon attacks outside the chance of being stacked on the same couple of guys by the flood of regular wounds from the DC. (As a side note I did some looking in the BBB and couldn't find anything preventing the one Jump Pack from joining his brethren, but I could be wrong and that would nix this whole strat) Conversion: No pics yet but in the spirit of the above flying ax I have just slapped some layered DP fins on the side of a Crusader without the tracks. One on top and the other four in pairs on each side. It's ugly but it works until I can scrape together some cash for a Valk for my real attempt. :rolleyes: Edit: Only one game in so far as I only got my Dex on Thurs. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2346063 Share on other sites More sharing options...
BOBMAKENZIE Posted April 14, 2010 Author Share Posted April 14, 2010 Now after having to paint 3 raiders and 24 infantry + Display board it took alittle while to get an update on the Storm Raven. And here she is basically done. http://i5.photobucket.com/albums/y196/Bobmakenzie/BA/IMG_3535.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/BA/IMG_3534.jpg Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2361450 Share on other sites More sharing options...
Soups Posted April 14, 2010 Share Posted April 14, 2010 I bow before you my good sir. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2361455 Share on other sites More sharing options...
GuyKeefer Posted April 14, 2010 Share Posted April 14, 2010 Haha! Awesome! One could almost think Dante is part Noise Marine. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2361469 Share on other sites More sharing options...
Emperors Immortals Posted April 14, 2010 Share Posted April 14, 2010 LOL i spilled my coffee all over my keyboard - thankyou for such good lulz hehehehehe Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2361529 Share on other sites More sharing options...
IronKobra Posted April 14, 2010 Share Posted April 14, 2010 hahahahaha, awesome! never thought I'd see anyone actually do it :D Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2361568 Share on other sites More sharing options...
igotsmeakabob!! Posted April 14, 2010 Share Posted April 14, 2010 Can we get a closer shot at Dante playing his axe? AWESOME JOB. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362215 Share on other sites More sharing options...
Vel'Cona Posted April 14, 2010 Share Posted April 14, 2010 Can we get a closer shot at Dante playing his axe? AWESOME JOB. Seconded. This is HILARIOUS ;) Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362362 Share on other sites More sharing options...
BOBMAKENZIE Posted April 14, 2010 Author Share Posted April 14, 2010 http://i5.photobucket.com/albums/y196/Bobmakenzie/BA/CIMG0340.jpg Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362365 Share on other sites More sharing options...
Vel'Cona Posted April 14, 2010 Share Posted April 14, 2010 HAHA he looks like he's doing a wrestling pose, like "What was that? I couldn't hear you over the sound of how awesome I am." ;) Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362376 Share on other sites More sharing options...
Slim Pickens Posted April 14, 2010 Share Posted April 14, 2010 BWHAAAAA HAAAA HAAAA This is so awesome. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362661 Share on other sites More sharing options...
Demoulius Posted April 14, 2010 Share Posted April 14, 2010 i love you man....in a completly heterosexual kinda way :P Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362679 Share on other sites More sharing options...
Quantra Posted April 14, 2010 Share Posted April 14, 2010 That is pure awesome, best storm raven yet! I want one, don't think any other storm raven could make a BA player/fan smile as much as this one. Great job. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362783 Share on other sites More sharing options...
BrotherAtrox Posted April 15, 2010 Share Posted April 15, 2010 Greatest thing on the internet right here. Bravo. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2362956 Share on other sites More sharing options...
Demoulius Posted April 15, 2010 Share Posted April 15, 2010 guys at my local GW have painted the raven up and are holding a workshop on how to construct one. sadly im going off on a holiday so i cant be present for the actuall workshop but ive already contacted the local staff and they agreed to let me do the workshop at some later date :down: il make a "how to" topic for it when the time comes but in the meantime il post some pictures ;) at this angle you can see how big the thing really is, it almost comes to the top of the fortress of redemption...its a huge target, will be tough to hide this one :P and at a somewat different angle, shows some of the side details. tbh i dont really like the position of the hurican bolters, as they would be shooting anyone who would be jumping out in the back :) but maybe i can fix that a little when i make my own :woot: imho they did a great job of painting this model up as well :) they did some nice looking free hands on it and even asked me if i wanted to play with it. (declined though since im not sure how to use it yet....it will receive thorough playtesting :yes: ) so watch this space guys, next weekend (not the coming one, the one after that) il probably have my own :wub: Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2364390 Share on other sites More sharing options...
Hymirl Posted April 15, 2010 Share Posted April 15, 2010 Hehe. I like the conversion, comedy models like these are always fun. at this angle you can see how big the thing really is, it almost comes to the top of the fortress of redemption...its a huge target, will be tough to hide this one ;) Thats the best conversion for a Stormraven I've seen yet and looks like its worth every penny put into it. Most the ones I've seen look lame being badly altered toys or a chop job with a more or less unmodified rhino that just looks like pile of random parts than an actual drop ship. If you can get a 'how to' thread going that would be great. Link to comment https://bolterandchainsword.com/topic/195852-storm-raven/page/2/#findComment-2364487 Share on other sites More sharing options...
