Gearing my WGTDA
Rolfi
So after reading the Wolf Guard entry I can't find anything saying Guard in TDA cannot take melta bombs in addition to other equipment. The reason I need to know is because I was going to use the meltas as an easy way of doing wound allocation on some of my squads. Could someone please clarify this one for me?
And I'd like to say thanks for all the help from the boards here. This place really does help in getting a new Blood Claw started.
https://bolterandchainsword.com/topic/196343-gearing-my-wgtda/
Just a side note. When most people talk WA its when modles have more then 1 wound, as single wound models you can give wound as you like to in the squad. Unless I am misunderstanding your use of WA, I see no use that having meltabombs could bo of help.
Unless... THinking about it... You mean I only want to pay for meltabombs on 4 of my WG and the other 6 can die and I care not... If so then the annser is yes, and yes the ones you give the bombs to CAN be in TDA!!
I don't see the point either, since it turns out that all of my TDA WG are different anyway or are leading other packs.
Btw, doing WA to GH pack, which consists of RP, WG and 8 hunters with melta, standard, PW and MoTW is a nightmare. Repetitive nightmare :)
