Space wolf snowy bases?
I recently bought some snow flock from Galeforce Nine, but i am having difficulty getting it to work.
First off im using white craft glue but when i dip the base in the flock, i can still see black on the base in between.Should i base it white first?
Just thought i'd ask here since the fang probably see's more snowy bases then those pansy dark angels.
https://bolterandchainsword.com/topic/196449-space-wolf-snowy-bases/
The glue dries clear, you can add some white paint to it or paint the top of the base. Check out my gallery, I made clear resin bases to mimic ice and then used blue and green washes to give it an ice hue and then flocked it with snow and pva glue to let the base almost be seen.
I use a mix of two different techniques.
- Mix bicarbonate (dirt cheap from any groceries store) with white glue. You can add some water if you want the snow to have a wetter look.
- Smear the mixture on your base and flock normally with snow flock.
Not the best picture but it will do for now:
Winter base
Yep always always paint the base white first, otherwise you'll have a slightly off white base. After that you can yuse which every snow recipy you preffer, baking soda/flock/sugar with pva/water effect/gloss or matt varish. Any and all of these work well and if you want smooth icey snow then smooth over and if you want fresh crisp snow you can re dip in your chosen dry medium after you've finished or wait for it to dry and then add again for those deeper snow drifts. Dont forget your vehicles either, I saw a fantastic diorama by a chinese with directional snow effect and melted ice where exhausts and vents were that looked great. ooh for light snow effect on buildings try watered down pva glue and a windoleen spray bottle, spray directionally and then sprinkle with flock
There we go thats all I know!!
