Token Posted April 5, 2010 Share Posted April 5, 2010 Would a land raider dedicated transport give a kill point, if destroryed? What about a rhino? Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/ Share on other sites More sharing options...
Koremu Posted April 5, 2010 Share Posted April 5, 2010 Yes, in all Standard Scenarios. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348226 Share on other sites More sharing options...
Frosty the Pyro Posted April 5, 2010 Share Posted April 5, 2010 yes, and yes. All units give a killpoint. transports are units. Each individual combat squads is a unit. even a retinue (of which codex marines have none) is a unit independent from their character. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348230 Share on other sites More sharing options...
the sanguinor Posted April 5, 2010 Share Posted April 5, 2010 this is what makes me laugh about tau piranhas...you kill it then the drones and you get 2 kill points. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348288 Share on other sites More sharing options...
Sparhawk Posted April 5, 2010 Share Posted April 5, 2010 I thought I saw on a FAQ somewhere that the drones were not a separate KP. I could be mistaken about that though. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348311 Share on other sites More sharing options...
the sanguinor Posted April 5, 2010 Share Posted April 5, 2010 maybe..i didnt see it. but the drones count as a seperate unit and thats where i drew the 2 kill point conclusion from. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348316 Share on other sites More sharing options...
ShinyRhino Posted April 5, 2010 Share Posted April 5, 2010 From the INAT FAQ, v3.3: "TAU.30E.01 – Q: In Annihilation missions, do vehicle Gun Drones give up an extra Kill Point if they are all destroyed? A: Assuming all the Gun Drones for a vehicle or squadron aren‟t destroyed when their parent vehicles are destroyed, yes the squadron formed by vehicle Gun Drones is then worth a Kill Point when destroyed [RAW]." So, if you detach them, and they die while detached...they're a KP. If they die while attached, they are NOT a KP. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348371 Share on other sites More sharing options...
Sparhawk Posted April 5, 2010 Share Posted April 5, 2010 Blast...this is just one more chink in my armor of infallibility :P Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348382 Share on other sites More sharing options...
greatcrusade08 Posted April 5, 2010 Share Posted April 5, 2010 The same works for t-fire, if you kill the cannon the techy becomes an IC and therefore worth an extra KP.. if you kill the gunner first its only a single KP for both Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348420 Share on other sites More sharing options...
Frosty the Pyro Posted April 5, 2010 Share Posted April 5, 2010 greatcrusade08 said: The same works for t-fire, if you kill the cannon the techy becomes an IC and therefore worth an extra KP.. if you kill the gunner first its only a single KP for both no, they are always the same unit, they are purchaced from the same entry, no models that didnt exist before apear. Its one kp for both regardless of order. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2348563 Share on other sites More sharing options...
greatcrusade08 Posted April 6, 2010 Share Posted April 6, 2010 Frosty the Pyro said: greatcrusade08 said: The same works for t-fire, if you kill the cannon the techy becomes an IC and therefore worth an extra KP.. if you kill the gunner first its only a single KP for both no, they are always the same unit, they are purchaced from the same entry, no models that didnt exist before apear. Its one kp for both regardless of order. Read it again, once the cannon gets killed the gunner becomes an IC.. Ics are worth kill points on thier own. im pretty sure this was covered in a rules discussion Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2349434 Share on other sites More sharing options...
Hellios Posted April 6, 2010 Share Posted April 6, 2010 greatcrusade08 said: Frosty the Pyro said: greatcrusade08 said: The same works for t-fire, if you kill the cannon the techy becomes an IC and therefore worth an extra KP.. if you kill the gunner first its only a single KP for both no, they are always the same unit, they are purchaced from the same entry, no models that didnt exist before apear. Its one kp for both regardless of order. Read it again, once the cannon gets killed the gunner becomes an IC.. Ics are worth kill points on thier own. im pretty sure this was covered in a rules discussion Not this again! I think it can be read both ways... which way is correct... well I don't care... yes it's an IC and ICs are worth KPs but if the Techmarine and Thunderfire cannon form a unit and the Thundefire is destroyed do you get a KP for the thunderfire being destroyed as some of that unit is still left (the Techmarine) or when the Techmarine becomes an IC is it forming a new unit and so the Thundefire unit is ended and awards a KP. But generally if it is a unit then it awards KP, if vehicles are in squadrons you get 1KP for the squadron not the individual vehicles. Imperial Guard infantry platoons have their own rules and some other units like the mentioned Thundefire cannon and Devilfish are odd and can give away more than 1KP although people often disagree on these matters. Oh and Space Wolves Lone Wolf gives a KP to the enemy if it is still alive at the end of the game. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2349474 Share on other sites More sharing options...
Spacefrisian Posted April 6, 2010 Share Posted April 6, 2010 greatcrusade08 said: Frosty the Pyro said: greatcrusade08 said: The same works for t-fire, if you kill the cannon the techy becomes an IC and therefore worth an extra KP.. if you kill the gunner first its only a single KP for both no, they are always the same unit, they are purchaced from the same entry, no models that didnt exist before apear. Its one kp for both regardless of order. Read it again, once the cannon gets killed the gunner becomes an IC.. Ics are worth kill points on thier own. im pretty sure this was covered in a rules discussion Even if it becomes an IC its still a single unit entry that you have bought. Thats why Victory points are still better than killpoints. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2349846 Share on other sites More sharing options...
Frosty the Pyro Posted April 6, 2010 Share Posted April 6, 2010 greatcrusade08 said: Frosty the Pyro said: greatcrusade08 said: The same works for t-fire, if you kill the cannon the techy becomes an IC and therefore worth an extra KP.. if you kill the gunner first its only a single KP for both no, they are always the same unit, they are purchaced from the same entry, no models that didnt exist before apear. Its one kp for both regardless of order. Read it again, once the cannon gets killed the gunner becomes an IC.. Ics are worth kill points on thier own. im pretty sure this was covered in a rules discussion IC are not worth KP as models, they are worth KP as units. UNITS give KP, and IC are normaly there own individual unit (even with an attached retinue the IC is still its own unit, simply joined). The techmarine is not joined to the cannons units, it IS part of the cannons unit. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2349988 Share on other sites More sharing options...
Sparhawk Posted April 6, 2010 Share Posted April 6, 2010 Like Frosty said. I think an important distinction is that unlike other ICs the Techmarine cannot leave the TC. In fact, up until the TC is destroyed the Techmarine isn't even considered an IC. Link to comment https://bolterandchainsword.com/topic/197074-does-dedicated-transport-give-kill-points/#findComment-2350075 Share on other sites More sharing options...
