Warhorse47 Posted April 6, 2010 Share Posted April 6, 2010 Do you think I could use a small wolf figure to represent the Chooser? I can't find a raven I like and found a wolf for a charm bracelet. Any reasons it couldn't stand in? Thanks in advance. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/ Share on other sites More sharing options...
Godhead Posted April 6, 2010 Share Posted April 6, 2010 You can use pretty much anything to represent the Cots. I think the only stipulation the codex puts on it is that it can't be bigger then the runepriest. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349017 Share on other sites More sharing options...
Wolf Lord Hallbjorn Posted April 6, 2010 Share Posted April 6, 2010 I usually use a teleport homer from the vanilla marines terminator box. It's something that I have a few of but since the Sons of Russ don't teleport in, I have no other use for them aside from chooser markers. If my opponent has a problem with me using them since they're on infantry bases, I just grab a random bit out of my bag of wolfy bits. And yes, the only stipulation about the marker is that it be smaller than the rune priest. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349025 Share on other sites More sharing options...
Ullr Direfang Posted April 6, 2010 Share Posted April 6, 2010 well seeing (or at least i see it this way) as the CotS is basically a familiar, there is(shouldn't be) any reason why it can't be up to the RP what he has, so i see a wolf as working. i personally want to find a nice raven model just 'cause i like putting my mark on the roof of a building and think a "raven on perch" would be fitting of my deployment. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349054 Share on other sites More sharing options...
ORKILL Posted April 6, 2010 Share Posted April 6, 2010 I use one of the icons from the wolf pack box, mounted on a cut down toothpick and then the toothpick is on a regular round base. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349068 Share on other sites More sharing options...
The_Betrayed_Spacewolf Posted April 6, 2010 Share Posted April 6, 2010 what about the raven that comes with termie njal? or if you can find it the eagle from torquemada cortez from the =I= range Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349140 Share on other sites More sharing options...
lunchb0x Posted April 6, 2010 Share Posted April 6, 2010 I use a fuzzy unicorn that is the size of a warhammer wolf. True story. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349214 Share on other sites More sharing options...
Mithril hound Posted April 6, 2010 Share Posted April 6, 2010 I want- Bigger ones, for thunder-unicorn-cavalry! Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349220 Share on other sites More sharing options...
Spacefrisian Posted April 6, 2010 Share Posted April 6, 2010 You could try to get the Ulric Wolf priest thing from the Fantasy range. It come with a Raven and it makes an excellent Rune Priest model. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349479 Share on other sites More sharing options...
Barn Posted April 6, 2010 Share Posted April 6, 2010 This Terrain pack contains a raven on a fence post (if you look at the picture its in the top left corner). Thats what i use! Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349497 Share on other sites More sharing options...
wolf363839 Posted April 6, 2010 Share Posted April 6, 2010 I use a servo-skull mounted on a small plastic rock on a normal base. Servo skull is from the SM Devestators box. Looks pretty cool. Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349794 Share on other sites More sharing options...
TheLastHuzzah Posted April 6, 2010 Share Posted April 6, 2010 I did what wolf363839 did, make sure you're carefull with it, not the sturdiest piece of plastic ever made. I'm on glue fix #2. -Huzzah Link to comment https://bolterandchainsword.com/topic/197173-chosser-of-the-slain/#findComment-2349905 Share on other sites More sharing options...
