Swiftclaw Attack Bike
theonelawler
Hello!
I Used the fantasy cavalry bases they came with, chopped a 25mm round base and glued them into the short ends and then filled them in with green stuff, wait for that to dry and then filed them down, sprayed and based them.
Whole process takes a little bit of time but it looks much better then sticking them on those massive bases in my opinion.
You don't need to put bases under Attack bikes, but if you really want to, go with dreadnought 60mm base.
I use a 60mm base for mine - I know you don't need to but I prefer it because it puts the model on the same level as the rest of the bikes.
Maybe one day GW will develop an appropriately shaped base like they did for the bikes - for those of us who'd like to use them! :P
