Arjac
jjfelber
I made a load of terminators back around Jan 2009 - I used;
1)normal terminator legs
2)Large Shield and thunder hammer from the Space marine terminator sprue (hes supposed to have a big shield)
3)Forge world body and should pads
Arjac is the Ginger one on the Left;
http://i667.photobucket.com/albums/vv34/Sam260308/Space%20Wolves/ArjacTerminator4.jpg
Looking at the new stuff, just use normal space wolf terminators and try to get the large storm shield off a friend :P
https://bolterandchainsword.com/topic/197429-arjac/#findComment-2351954
I've an idea to build him from wolf termie parts based on something I saw in a White Dwarf from years ago. I think one of the 'eavy metal team back in probably 2nd ed. was a guy called Kim Syber. He built loads of Space Wolves including a conversion for Bjorn and a wolf lord apparently made from 57 different parts. I seem to remember from back then (but I could be wrong) that there was a story about a particularly massive Space Wolf who wore TDA and was a bit of a beast. I don't think he was a character in the list but Kim Syber built him up from wolf parts. He added plasticard to the joints to bulk him out and make him taller. Anyway, I'm going to give it a go as Arjac is cool (trying throwing his hammer at a big beastie and follow it up with Jaws of the World Wolf...).
https://bolterandchainsword.com/topic/197429-arjac/#findComment-2352141
Consider anatomy and physiology when building him. Especially if you want to have him about to throw his hammer.
With the current plastics, and a semi decent grasp of the use of putty, it should be able to be done...why cant i draw with my computer...is there an app for that?, nevermind. if you remove the shoulder on the hammer arm, twist arm into throwing position, and then reconstruct the shoulder with gs. i hope this made some sense. or at least i hope mo one is totally confused. anatomy and physiology is the key
https://bolterandchainsword.com/topic/197429-arjac/#findComment-2352371
My WIP - I am building him as versatile as I can. He will be Arjac, WL, WGBL or random TH/SS wolf guard, depending on needs. I also magnetised his right arm to swtch between FB and TH.
Arjac
Frost blade arm
Front view - armless
And DV8's performance is as always stunning!
https://bolterandchainsword.com/topic/197429-arjac/#findComment-2352959
