Karsus Posted April 8, 2010 Share Posted April 8, 2010 1. Just how many shots are fired on LR Crusader's one hurricane bolter? It's written ti's 3 TL HB as one weapon, so it's 3X3 = 9 shots? 2. Can Njal get +1 attack from his pistol, when he's wearing his Runic TDA? Or is it typo? 3. Wolf Guard, in PA, cannot get extra attack when equipping Wolf Claw or Power Fist, with pistol, right? Young pups need old wolve's guidance....For Russ, all. Link to comment https://bolterandchainsword.com/topic/197589-some-pup-questions/ Share on other sites More sharing options...
Matt D Posted April 8, 2010 Share Posted April 8, 2010 1) it fires 3 shots at 24 and 6 at 12 as it is 3 twinlinked bolters. 2) nope 1 attack is all :) 3) correct. unless you have a pair of either. Link to comment https://bolterandchainsword.com/topic/197589-some-pup-questions/#findComment-2353590 Share on other sites More sharing options...
Lumdin Posted April 8, 2010 Share Posted April 8, 2010 1) depends on range. at 24 " using both hurricaine bolters thats - 6 Twin Linked Bolter shots at 12 " using rapid fire that 12 Twin linked bolter shots Hurricaine bolters are not heavy bolters they are just regular bolters. So if you move 6" inches , you can fire all your hurricaine bolters (str 4 defensive weapons), 1 main weapon TL assault cannon, and then use machine spirit to fire a Multi melta if you purchased it. 2) Not familiar with Njal's stats so dont know what weapons he has, sorry 3) Correct Link to comment https://bolterandchainsword.com/topic/197589-some-pup-questions/#findComment-2353595 Share on other sites More sharing options...
pucadubh Posted April 8, 2010 Share Posted April 8, 2010 Hurricaine bolters are not heavy bolters they are just regular bolters. So if you move 6" inches , you can fire all your hurricaine bolters (str 4 defensive weapons), 1 main weapon TL assault cannon, and then use machine spirit to fire a Multi melta if you purchased it. No offense meant to Brother Lumdin but just to be clear for Brother Karsus, do not underestimate these babies. At short range these hurricanes are deadly, 12 twin linked bolter shots together with 4 twin linked assault cannon shots and then the multi-melta on top = AWESOME. Ghazghull stepped out in front of one (alone ... long story) of mine and laughed off the fact that I couldn't kill him with all these shots at 12" however they did get him down to 1 wound and then the assault termies unloaded :huh: I have even had people say at least its not a redeeemer until it opens up. This vehicle is awesome as a delivery system that will chew up almost anything in the way and even if it is uber it will be much softer when the passengers hit. Redeemer is the best against hordes and clustered units but the Crusader will hurt anything and then the many passengers unload :D Link to comment https://bolterandchainsword.com/topic/197589-some-pup-questions/#findComment-2353864 Share on other sites More sharing options...
Ullr Direfang Posted April 8, 2010 Share Posted April 8, 2010 2) nope 1 attack is all :) this is wrong, or you were misunderstood by Matt D everything has bee said before on the others, but Njal has a bolt pistol when wear TDA, so in combat he gets the +1 for having 2 CCW. Link to comment https://bolterandchainsword.com/topic/197589-some-pup-questions/#findComment-2353899 Share on other sites More sharing options...
Matt D Posted April 9, 2010 Share Posted April 9, 2010 my bad. i misunderstood the question. Link to comment https://bolterandchainsword.com/topic/197589-some-pup-questions/#findComment-2355034 Share on other sites More sharing options...
Spacefrisian Posted April 9, 2010 Share Posted April 9, 2010 Also note that Njall wears "Runic" Terminator armour in wich only he is skilled in using, that means he is also skilled in using a Boltpistol with it. Link to comment https://bolterandchainsword.com/topic/197589-some-pup-questions/#findComment-2355278 Share on other sites More sharing options...
