breng77 Posted April 11, 2010 Share Posted April 11, 2010 A question that came up the other day in a game I was playing was whether a unit that goes to ground has to take a morale check for taking 25% casualties. I argued that it did as it states in going to ground that a unit still must take actions caused by your opponent was I right in this? Link to comment Share on other sites More sharing options...
Ashe Darke Posted April 11, 2010 Share Posted April 11, 2010 This came up the other day as well and we came to conclusion that a unit that goes to ground and suffers 25% casualties still need to take their morale test. Link to comment Share on other sites More sharing options...
Legatus Posted April 11, 2010 Share Posted April 11, 2010 My rulebook specifically says on page 24 that units that have gone to ground still take Morale tests as normal. Doesn't your rulebook say that? Link to comment Share on other sites More sharing options...
breng77 Posted April 12, 2010 Author Share Posted April 12, 2010 Yeah, and that was how we played it but my opponent was still convinced that they did not have to. I wasn't sure if it was in the FAQ or something like that. Link to comment Share on other sites More sharing options...
stinkenheim Posted April 12, 2010 Share Posted April 12, 2010 units that have gone to ground (either voluntarily or through pinning) are unable to perform any actions of their own volition in their following turn. however most morale checks ar not done in their following turn, the are done in the enemies turn and as such will force a pinnedunit to fall back should they suffer enough wounds. units that are pinned may also fight in an assault should they be charged, so would have to take a morale test should they lose the combat. i see no reason to say that units that have gone to ground in effect become fearless as they are already hiding out of fear (or self preservation, wahtever you wish t call it) and so in their already frightened or paniced state they would be more prone to falling back in the face of superior firepower or scary looking gribbly things running towards them... just how i see it anyway, but as has been said its in the BRB on p. 24. Link to comment Share on other sites More sharing options...
Agrab Posted April 12, 2010 Share Posted April 12, 2010 Units that are pinned can not do anything on their own, but they must respond to things from the other side. If they are forced to take the moral test (more than 25%, charged (if fallen to ground and charged you must take the test, if you don't or fail, you die)). Also, even if they went to ground, they must take the test that turn if they took too many casualties. For instance, snipers kill 2 of an 8 man unit, the unit pin tests first (at end of that shot, prior to any other shooting unit) and then moral at end of turn, even if they went down. Link to comment Share on other sites More sharing options...
stinkenheim Posted April 12, 2010 Share Posted April 12, 2010 @ Agrab, i can't seem to find where in the rules a unit that has gone to ground runs the risk of being destroyed should it get assaulted, indeed on p 24 of the BRB, in the box labled Going To Ground the rules state '... Whilst it has gone to ground the unit may do nothing of its own volition, but will react normally if affected by enemy actions (for example, it will take morale tests as normal). If the unit has to fall back, it will return to normal immediately. If assaulted, the unit will fight as usual, but gains no advantage for being in cover...' to my knowledge the only time a unit is destroyed should it be assaulted (or rather runs the risk of being destroyed) is if it is assaulted whilst falling back. Link to comment Share on other sites More sharing options...
Agrab Posted April 12, 2010 Share Posted April 12, 2010 @ Agrab, i can't seem to find where in the rules a unit that has gone to ground runs the risk of being destroyed should it get assaulted, indeed on p 24 of the BRB, in the box labled Going To Ground the rules state '... Whilst it has gone to ground the unit may do nothing of its own volition, but will react normally if affected by enemy actions (for example, it will take morale tests as normal). If the unit has to fall back, it will return to normal immediately. If assaulted, the unit will fight as usual, but gains no advantage for being in cover...'to my knowledge the only time a unit is destroyed should it be assaulted (or rather runs the risk of being destroyed) is if it is assaulted whilst falling back. I am trying to remember where, but i need to get the rulebook out everygame to point it out it is either in the going to ground section OR in the moral section. Link to comment Share on other sites More sharing options...
Seahawk Posted April 12, 2010 Share Posted April 12, 2010 There is no need for a FAQ. The rules clearly state that if you suffer casualties when gone to ground, you take a Morale Check, simple as that. and then moral at end of turnEnd of phase. It's hilarious to watch deepstrikers land in terrain then suffer enough casualties to flee before the shooting phase begins. I am trying to remember where, but i need to get the rulebook out everygame to point it outit is either in the going to ground section OR in the moral section. It's in the morale section. It's only when you're actually fleeing and get assaulted that you take the Leadership or die. Link to comment Share on other sites More sharing options...
Agrab Posted April 12, 2010 Share Posted April 12, 2010 There is no need for a FAQ. The rules clearly state that if you suffer casualties when gone to ground, you take a Morale Check, simple as that. and then moral at end of turnEnd of phase. It's hilarious to watch deepstrikers land in terrain then suffer enough casualties to flee before the shooting phase begins. I am trying to remember where, but i need to get the rulebook out everygame to point it outit is either in the going to ground section OR in the moral section. It's in the morale section. It's only when you're actually fleeing and get assaulted that you take the Leadership or die. I meant phase. I have had that happen (i much prefer the deepstrike, scatter, mishap, roll and die better) only when fallingback? Hmmm, for some reason i was putting them together in my mind Link to comment Share on other sites More sharing options...
