Wolf Guard Wargear
Brother Tholath
p 86 of the codex says 'Any wolf Guard may replace bolt pistol and/or close combat weapon with XXXX', it also says 'Any Wolf Guard may replace power armour, close combat weapon, bolt pistol, frag and krak grenades with terminator armour, storm bolter and power weapon...' and lastly 'Replace Terminator armours storm bolter/power weapon with XXXX'.
this means that if you have a wolf guard unit ay member of it may take termiantor armour. any memebr of the squad may also take any two weapon choices, regardless of what weapons they are. the only limitation is that you need 5 models to take one heavy weapon, or ten models to take two heavy weapons, only models in terminator armour are capable of taking the heavy weapons but you don't need five terminators to access them.
I think I might not be explaining myself, I know what you have said is correct, but the Wolf Guard don't have to follow the rule of no 2 models using the same wargear, a fre people I've asked said they they follow the same rule that all the HQs do but I was thinking that is kinda silly.
p 81 of the codex.
The Leaders of the Pack.
...However, packs of space wolves work best when led by a single dominant personality, ech hero respected for his own abilities. To represent this, no two character may bear the same saga, nor may the bear the same psychic powers or wargear combination...
this rule as it states only applies to chracters, wolf guard are units not characters and so do not suffer from te restrictions imposed other wise you would not be able to field more than one grey hunter as they all have the same wargear. the rule applies to HQ choices alone
p 81 of the codex.
To further confirm this, note the Asterisk * next to the Leaders of the Pack rule, and then note the Asterisks next to the "HQ" on the top of the next couple of pages... but NOT on the elites pages.
