Token Posted April 11, 2010 Share Posted April 11, 2010 Would SW termie heads fit on a normal marine? Or are the necks to big? Link to comment https://bolterandchainsword.com/topic/197928-would-sw-termie-heads-fit-on-a-normal-marine/ Share on other sites More sharing options...
Legacy Posted April 11, 2010 Share Posted April 11, 2010 the termie heads come with this little half ball on thier neck so the head can stick out of the armour and be seen. Just file the neck ball down and they should fit fine. Link to comment https://bolterandchainsword.com/topic/197928-would-sw-termie-heads-fit-on-a-normal-marine/#findComment-2357737 Share on other sites More sharing options...
pucadubh Posted April 11, 2010 Share Posted April 11, 2010 In reverse, the wolf head helmets look great on the Termies too! Link to comment https://bolterandchainsword.com/topic/197928-would-sw-termie-heads-fit-on-a-normal-marine/#findComment-2357766 Share on other sites More sharing options...
stinkenheim Posted April 11, 2010 Share Posted April 11, 2010 if you are talking about the bare heads then they are the same size as power armoured heads with the half ball neck joint and so will fit perfectly. the helmets would need more work though but would fit ok, although they may look a bit goofy if you ask me. as a side note marine helmets fit pretty well on terminators, although some clipping may be needed at the back, the knightly looking helmets for instance work really well although not the right look for wolves. Link to comment https://bolterandchainsword.com/topic/197928-would-sw-termie-heads-fit-on-a-normal-marine/#findComment-2357776 Share on other sites More sharing options...
Token Posted April 11, 2010 Author Share Posted April 11, 2010 Thanks. Link to comment https://bolterandchainsword.com/topic/197928-would-sw-termie-heads-fit-on-a-normal-marine/#findComment-2357803 Share on other sites More sharing options...
