Blackadder Posted April 14, 2010 Share Posted April 14, 2010 Well I did it and I'm glad. Back in the days when my son was just starting out in 40K gaming we bought a tired old Armorcast Baneblade on Ebay and refurbished it. Although he was in ecstasy over it I was always bothered by the rather primitive design and the cranium sized rivets so after I replaced it with a Mars Pattern Baneblade (his fav not mine) I asked him if I could do a bit of a face-lift on the old relic. http://i.imagehost.org/0612/4_23.jpg As usual my documentation is sporadic and there's a lot of pictures of the same thing. My biggest regret is not showing the step by step manufacture of the demolisher cannon which I am especially proud of. Casting new lascannons for the sponsons is missing but the actual barrel manufacture is available so let's get started with a battle board scene of the tank company and the hapless Armor cast Baneblade in her prime. Here we see the victim in my favorite color scheme, http://i.imagehost.org/0989/1_80.jpg Gray sandable primer with flat black accents. http://i.imagehost.org/0517/2_34.jpg http://i.imagehost.org/0820/5_2.jpg Not too big on camouflaging Superheavy tanks as the true life dimensions are literally as big as my house so other that disguising it as a boulder there's not much point. The Lucius Pattern Baneblade in the foreground is my favorite tank. http://i.imagehost.org/0314/3_29.jpg I picked it up on EBay for next to nothing and it was a pitiful wreck with the treads glued on backwards and globs of glue and paint all over it. After I lovingly scrapped all the paint and glue off I pried apart all the pieces with surprisingly little breakage and reassembled. That project will be documented in another thread. EB Link to comment Share on other sites More sharing options...
jester_prince Posted April 14, 2010 Share Posted April 14, 2010 "Not too big on camouflaging Superheavy tanks as the true life dimensions are literally as big as my house so other that disguising it as a boulder there's not much point. " Cammo on tanks is probably more for the advantage it gives against airborne units then infantry, like you said it would be pointless disguising your house to infantry but when your half a mile up it could make all the difference. i know during ww2 they used to dress hay bails up to look like tanks and cammo net the real tanks so that airborne units would target the hay bails. Target recognition from above is alot more difficult when your so high up, even in the 41 millennium id imagine. So for the sake of your tank crews :o please reconsider camouflaging your house, i mean tanks. :P tho i do like the grey, it is perfect for urban combat, which is where these beasts look like they should belong, crushing smaller houses and tank wreckage beneath their awesome treads. all joking aside good look i never liked the armour cast models personally, they look simplistic and like a child's toy from the 80s, all large parts that are over exaggerated, especially their titans, i look forward to the makeover. Link to comment Share on other sites More sharing options...
Blackadder Posted April 14, 2010 Author Share Posted April 14, 2010 Cammo on tanks is probably more for the advantage it gives against airborne units then infantry, like you said it would be pointless disguising your house to infantry but when your half a mile up it could make all the difference. i know during ww2 they used to dress hay bails up to look like tanks and cammo net the real tanks so that airborne units would target the hay bails. Target recognition from above is alot more difficult when your so high up, even in the 41 millennium id imagine. So for the sake of your tank crews :D please reconsider camouflaging your house, i mean tanks. :D Thanks for the in depth reply. It's nice to read a considered opinion and I appreciate the time you took to answer. While my rational of the gray looking like a gray bolder in a field is half joking no camouflage is going to cover all situations. My gray tanks would stand out like a sore thumb in a desert setting or a red sandstone area. One would think in the far distant future (As if tanks and the like would have any role at all on the battlefield.) the paint would be programmable to emulate the surroundings chameleon-like and the true base colour would be something neutral such as say gray? ;) First order of business is to get rid of the outrageous over-sized rivets http://i.imagehost.org/0330/6_6.jpg http://i.imagehost.org/0635/7_13.jpg and cut out the sponsons for a drum mounted pair of bolters. http://i.imagehost.org/0031/8_13.jpg I find a razor saw and sandpaper invaluable in modifying resin models, also the resin does not hold paint very well so scraping with a dull Exacto #11 tip while time consuming will remove all the paint down to the bare resin. The truth be know I just happen to like gray. EB Link to comment Share on other sites More sharing options...
Blackadder Posted April 14, 2010 Author Share Posted April 14, 2010 I take a rather dim view of the new GW Baneblade considering the bottom has dropped out of the resin Baneblade market. My hard won Forgeworld Baneblades have lost considerable value since the advent of this kit and I'm surprised Forgeworld hasn't protested this copy. LOL I'll not be using any parts from the Baneblade plastic kit. Almost every thing will be cast or scratch built including the nuts on the bolt on bumper. Rivets are the easiest of all, I use various sized straight pins. Pins have the added value of anchoring the armor panels where plastic is glued on resin and at the scale we're talking a round head and a hex head bolt are too similar to be concerned about IMHO. About the only bits I used are the various hatches and doors and vents mainly from Leman Russ and Chimera kits. The chopping continues: http://i.imagehost.org/0388/9_17.jpg If I had it to do over again, I probably would not have chopped up the turret as apart from the excellent mount lock design there was very little left of the original turret when I finished. http://i.imagehost.org/0770/10_7.jpg I feel like Sweeney Todd, The Blackadder Time to stop my mad careering path of destruction and actually do something constructive. Using industrial quality 'Met-all' epoxy I formed the rear storage compartments on the turret and by laminating sheets of styrene from the slat of a cheap Venetian Blind fabricated the front turret shield. The strap hinges are from round stock and blind material. http://i.imagehost.org/0679/11_19.jpg The main gun is a gray marker pen and the secondary gun is scratchbuilt out of various sized plastic tubing. styrene blind strips formed the edge gusset strips and decorating pins for Styrofoam ornaments cut to length form the rivets. I'm more than a little irritated that I didn't document the fabrication of the front hull details. The forward viewport hatch approximated the one that is offered as a bitz from the chimera kit that I didn't know was available. I have the dubious knowledge that mine required a couple of hours labor. The headlight housings, armor, hatch with periscope, periscope forward viewport splash shield were all hand crafted from styrene. Flare launchers and winged skull are the only bitz in the picture. Insanity thy name is Blackadder Link to comment Share on other sites More sharing options...
dark_claw Posted April 14, 2010 Share Posted April 14, 2010 i have to say i followed your titan blog and im following this one you son is lucky to have you do all this for him i wish my own father could lol the closest he came tho was playing space crusade lmao great work keep it up Link to comment Share on other sites More sharing options...
Blackadder Posted April 16, 2010 Author Share Posted April 16, 2010 I tried casting lascannons but the detail was too fine so I opted to make them from scratch. The lascannon turrets were cast from the Forgeworld turrets using latex rubber moulds which in themselves are very hard to make. If anyone knows an easy way to make latex moulds, I would appreciate the input. http://i.imagehost.org/0443/12_6.jpg I had purchased a bag of mixed brass tubing scraps years ago at a hobby fair and with a razor saw and jewellers files a managed to cobble together a fair looking set of lascannons. http://i.imagehost.org/0874/13_4.jpg The lascannon base was a piece of thin printer case material and the electrical cable the very thinnest styrene rod superglued together and inserted into a very thin brass collar. The cannon barrel and details were all superglued together (no soldering required) drilling an appropriate sized hole into the turret and supergluing the cannon assembly into the turret brought me to the stage pictured below. An application of a thin coat of grey primer to reveal the flaws, revealed no flaws. http://i.imagehost.org/0173/14_27.jpg Imagine that, The Blackadder Link to comment Share on other sites More sharing options...
