Coverfire Posted April 27, 2010 Share Posted April 27, 2010 In the Razorback Box Set, which weapons options do you get these days? Is it still just TWL Heavy Bolter and TWL Lascannon or have they added Lascannon/ TWL Plasmagun Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/ Share on other sites More sharing options...
Sarapham Posted April 27, 2010 Share Posted April 27, 2010 Nope no Las/Plas yet, just TLHB and TLLC. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2378445 Share on other sites More sharing options...
Grey Mage Posted April 27, 2010 Share Posted April 27, 2010 Still a good value compared to a rhino though, and the TLLC is pretty easy to convert over into a Las/Plas. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2378455 Share on other sites More sharing options...
Simo429 Posted April 27, 2010 Share Posted April 27, 2010 dont understand why they make the rhinos at all i bought two rhinos to start with and it was obviously a real aste of time Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2378632 Share on other sites More sharing options...
mitchell93 Posted April 27, 2010 Share Posted April 27, 2010 i have rhinos for my full strength grey hunter pack Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2379059 Share on other sites More sharing options...
Stormbrow II Posted April 27, 2010 Share Posted April 27, 2010 I think he means buying as in €, not in Army Lists. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2379397 Share on other sites More sharing options...
mastrchief33 Posted April 27, 2010 Share Posted April 27, 2010 Go to bitz barn if you need to make the assault cannon turret. They sell the LRC/LRR version for like 6.00 USD. As was mentioned, the Las/plas isn't too hard to convert. I don't really know how you'd go about heavy flamers. Probably have to go FW immolator, assuming that even comes with heavy flamers. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2379480 Share on other sites More sharing options...
WolfLord Digby Posted April 28, 2010 Share Posted April 28, 2010 Makes sense to buy razorbacks over rhinos just for the extra bitz... Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2380506 Share on other sites More sharing options...
wisdom like silence Posted April 28, 2010 Share Posted April 28, 2010 If you want the assault cannon razorback and happen to have Ravenwing bits sitting around (I did) you can use the assault cannons they supply for the speeder and basically just replace the barrels of the heavy bolter with the rotary part of the assault cannon. it look virtually identical (but a bit longer) to the plastic TLAC that comes with the LRC. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2380542 Share on other sites More sharing options...
Mordekiem Posted April 29, 2010 Share Posted April 29, 2010 I think the las/plas is a throwback to the 2nd edition razorbacks. They had turrets like that at the time. They took the option out in 4th and I am sure they had a ton of complaints about suddenly unusable models. I know I was a sad panda because that was my favorite loadout and I spent alot of time orderign and hunting down those turrets. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2381222 Share on other sites More sharing options...
Grimtooth Posted April 29, 2010 Share Posted April 29, 2010 This was a question that came up when I was making out a shopping list. I want to run 3 rhinos and 2 razorbacks. So ideally for the extra turrets I should just buy 5 razorbacks and then be able to field my 3 rhinos and have the extra parts for swapping out turret systems on my two razorbacks? Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2381229 Share on other sites More sharing options...
Silverwolf Posted April 29, 2010 Share Posted April 29, 2010 Yeh basically. Lets you setup a variety of turret options for use ont he Razorbacks, and also change how many Razorbacks vs Rhinos your running in your list. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2381244 Share on other sites More sharing options...
Grimtooth Posted April 29, 2010 Share Posted April 29, 2010 Yeh basically. Lets you setup a variety of turret options for use ont he Razorbacks, and also change how many Razorbacks vs Rhinos your running in your list. Cool, I gotta take a rhino back and pay the difference. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2381475 Share on other sites More sharing options...
Marek Grimfang Posted April 30, 2010 Share Posted April 30, 2010 The newish GW store in Vaughan has the BA Razorback set in the cabinet. It comes with the Las-Plas combo. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2382591 Share on other sites More sharing options...
Silverwolf Posted April 30, 2010 Share Posted April 30, 2010 BA Razorback? Even the GW site still only has the generic Razorback listed... Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2382625 Share on other sites More sharing options...
Whitefireinferno Posted April 30, 2010 Share Posted April 30, 2010 The newish GW store in Vaughan has the BA Razorback set in the cabinet. It comes with the Las-Plas combo. HAS to be a conversion, We did get some cool new things But a new razorback was not one of them. BA Razorback? Even the GW site still only has the generic Razorback listed... Because we did not get one, thus its a conversion :D. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2382645 Share on other sites More sharing options...
Grimtooth Posted April 30, 2010 Share Posted April 30, 2010 Well two razorbacks bought, 3 more to go. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2382812 Share on other sites More sharing options...
Ikken Posted April 30, 2010 Share Posted April 30, 2010 hi same question , but about predators what gun options do you get with the standard kit ? and do you get the rhino sides and top in the predator kit so you can make it interchangeable . ? Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2383494 Share on other sites More sharing options...
Grey Mage Posted April 30, 2010 Share Posted April 30, 2010 Its alot more difficult to make a predator readily interchangeable to a rhino and back, but yes.... all of the kits that look like they are based on rhinos ARE in fact based on rhinos. And you get both turret and both sponson options, and a stormbolter, search light, smoke launchers, HK Missile, and a couple of other bitz. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2383540 Share on other sites More sharing options...
LoneSniperSG Posted April 30, 2010 Share Posted April 30, 2010 I think the las/plas is a throwback to the 2nd edition razorbacks. They had turrets like that at the time. They took the option out in 4th and I am sure they had a ton of complaints about suddenly unusable models. I know I was a sad panda because that was my favorite loadout and I spent alot of time orderign and hunting down those turrets. I love their fluff explanation for it in C:SM though. "No one is certain what circumstances married such a devastating weapon loadout to such a fragile chassis." Which is true. What's the purpose of it? Am I not mistaken that it's twin lascannons and a plasma cannon in the middle? That's a sheep of a lot of firepower. Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2383563 Share on other sites More sharing options...
Demonslayer Posted April 30, 2010 Share Posted April 30, 2010 I think the las/plas is a throwback to the 2nd edition razorbacks. They had turrets like that at the time. They took the option out in 4th and I am sure they had a ton of complaints about suddenly unusable models. I know I was a sad panda because that was my favorite loadout and I spent alot of time orderign and hunting down those turrets. I love their fluff explanation for it in C:SM though. "No one is certain what circumstances married such a devastating weapon loadout to such a fragile chassis." Which is true. What's the purpose of it? Am I not mistaken that it's twin lascannons and a plasma cannon in the middle? That's a sheep of a lot of firepower. Wrong way around, Twin-Linked Plasma gun with Lascannon, Now to work out how I'm going to do this Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2383603 Share on other sites More sharing options...
Demonslayer Posted April 30, 2010 Share Posted April 30, 2010 I think the las/plas is a throwback to the 2nd edition razorbacks. They had turrets like that at the time. They took the option out in 4th and I am sure they had a ton of complaints about suddenly unusable models. I know I was a sad panda because that was my favorite loadout and I spent alot of time orderign and hunting down those turrets. I love their fluff explanation for it in C:SM though. "No one is certain what circumstances married such a devastating weapon loadout to such a fragile chassis." Which is true. What's the purpose of it? Am I not mistaken that it's twin lascannons and a plasma cannon in the middle? That's a sheep of a lot of firepower. Wrong way around, Twin-Linked Plasma gun with Lascannon, Now to work out how I'm going to do this Link to comment https://bolterandchainsword.com/topic/199696-razorback-box-set-options/#findComment-2383604 Share on other sites More sharing options...
