wolf guard cyclone WIP
http://th02.deviantart.net/fs71/300W/i/2010/122/6/b/wolf_guad_cyclone_launcher_WIP_by_bigbigs33.jpg
There ;)
Looks good... WYSIWYG natzi's may smack you over the head for that S.Shield though... unless he acctually has one?
Without the dex in front of me... don't think can take S.Bolter, S.Shield, and CM.Launcher
I know you retain a weapon, but do you retain both? From memory can't WG in TDA replace they're S.Bolter OR P.Weap (or both) with a S.Shield? Does the CML replace a weapon, or is just in addition to whatever gear you already have? I know the Ass.Can & Hvy.Flamer replace gear, but can't remember if the CML does ;).
I know you retain a weapon, but do you retain both? From memory can't WG in TDA replace they're S.Bolter OR P.Weap (or both) with a S.Shield? Does the CML replace a weapon, or is just in addition to whatever gear you already have? I know the Ass.Can & Hvy.Flamer replace gear, but can't remember if the CML does :).
You can replace either the storm bolter or the power weapon for the Storm Shield, so thats fine. You also dont need to give up either to take a Cyclone Missle launcher :)
Thanks Barn :), I really should bring my dex to work :P
the storm shield is purely for show
It looks good :), but one suggestion... use Rare Earth Magnets to attach the S.Shield arm, and paint up a P.Weap arm with a magnet in it as well. That way if you decide to go to any tournies that are WYSIWYG tournies you can replace the arm and avoid issues with WYSIWYG fanatics ;)
With the mates I play with its not an issue... we've used Nintendo64 Cartridges as Chimeras etc on occasion ;), but in terms of playing at a tourny, I find its usually best to avoid such issues :)
Edit:... wow thats a lot of smilies I just used...
