Scrambles Posted May 8, 2010 Share Posted May 8, 2010 I have heard different methods of using Terminators and "termicide" sounds common. What are different strategies with Terminators that everyone has come up with? Please explain them and also the termicide method. Link to comment Share on other sites More sharing options...
minigun762 Posted May 8, 2010 Share Posted May 8, 2010 I have heard different methods of using Terminators and "termicide" sounds common. What are different strategies with Terminators that everyone has come up with? Please explain them and also the termicide method. Termicide refers to 3-4 Terminators with Combi-Melta deepstriking in and frying a tank. You expect the squad to die shortly after (hence the -cide part). In essence, you're trading your Terminators for their tank/artillery/transport. People try to go with Assault Terminators in a Land Raider, but our Land Raider isn't nearly as good as Loyalists and we don't have access to TH/SS Terminators either. Its possible to do it, but Terminators work better as deepstriking support. Some people are trying their hand at larger squads of 5-6 Terminators and deepstriking them in. The goal is that they do more than killing just a single unit. Link to comment Share on other sites More sharing options...
Chengar Qordath Posted May 9, 2010 Share Posted May 9, 2010 People try to go with Assault Terminators in a Land Raider, but our Land Raider isn't nearly as good as Loyalists and we don't have access to TH/SS Terminators either. Its possible to do it, but Terminators work better as deepstriking support. Chaos Assault Terminators do have some advantages; the ability to add a heavy flamer is nice, and icons can be useful for increasing the unit's attack power or durability. Slaanesh can be particularly useful since it's fairly cheap and hitting at initiative 5 is a major help against other Marines. Link to comment Share on other sites More sharing options...
David the Despoiler Posted May 9, 2010 Share Posted May 9, 2010 I normally use Terminators as high armor save and 4+ invulnerable wounds for when I field Abaddon the Despoiler in a Land Raider. Cheese, maybe, but against Thunderwolf Cav, something must be done! In smaller point games, termi-cide is 3 termis, one with a heavy flamer and two with combi-flamers for me. That's a 105 point unit that I've had annihilate an entire platoon-command of Guardsmen (heavy flamers were made to kill guardsmen, I tell you!). Link to comment Share on other sites More sharing options...
the jeske Posted May 9, 2010 Share Posted May 9, 2010 Chaos Assault Terminators do have some advantages; the ability to add a heavy flamer is nice, and icons can be useful for increasing the unit's attack power or durability. Slaanesh can be particularly useful since it's fairly cheap and hitting at initiative 5 is a major help against other Marines. 5 man sized . no crusader , so no frags on charging out , making IoS a crap choice . LR does not have PotMS. They are not fearless and can actualy run from hth. Huge problems with other assault/counter units . Icons with 10 man can die ,icons with 5 man will die. They still have to be baby sited by an HQ .. so its actualy 4 termis and taking a chaos non DP HQ is another sad story[instant killed , low inv only +3 sv] . Also when trying to run a cost optimized unit they arent that good [dont kill enough] , when buffed up with icons champions etc they cost too much while still having all the downsides of cheap units. No chaos termis are not a good assault unit. Link to comment Share on other sites More sharing options...
Scrambles Posted May 9, 2010 Author Share Posted May 9, 2010 I have three squads of five Terminators, they seem to be played as an Assault unit more than ranged, their upgrades move them in this direction. Unless someone knows of a good range strategy with them. Loyalist, you mean Space Marine, right. The GreyKnight Land Raider is more expensive than the Chaos and recieves less. It sounds like the Chaos Landraider has a bad rep though. Link to comment Share on other sites More sharing options...
the jeske Posted May 9, 2010 Share Posted May 9, 2010 The GreyKnight Land Raider is more expensive than the Chaos and recieves less better smokes , PotMS . Unless someone knows of a good range strategy with them. shot . shot . turn 3 rhino wall or tank shock and shot . turn 4 counter what is left. that is with meq. eldar/tau fly around and shoting at them . Slogging termis is a very very very bad idea. Link to comment Share on other sites More sharing options...
Brother Nihm Posted May 9, 2010 Share Posted May 9, 2010 One would almost think that searching has gone out of fashion, Chaos Terminators, Why just termicide? Termicide, Stories/opinions Best use of Chaos Termicide?, Use for Chaos Terminators Flamercide, 3 termies 2 combi flamers 1 heavy flamer Termicide tactics? Four-man Termicide config, Spreading the wealth How do termicide squads work?, How do these guys take out a land raider? Termicide Link to comment Share on other sites More sharing options...
