faol Posted May 10, 2010 Share Posted May 10, 2010 I've had an idea of an Iron Father in mind but my problem is how do I get this basically the tank halfX-man Reaver Bonebreaker I've been mulling over this for months I just dont know what model to use or scale Link to comment Share on other sites More sharing options...
Durus Posted May 10, 2010 Share Posted May 10, 2010 You could use the tracks from a wartrakk, a thunderfire cannon, use the track bits from ramshackle games or find a robogear toy with tracks or something comparable. I think a 1:72 scale tank model would work as well. Maybe even a bigger scale kit of a scout vehicle with one of those trailer/drone thingies. Forgeworld recently announced to release some Grot tanks. If you want smaller tracks you could take a look at the Ork warbikers. one of the bikes comes with some tracks in the back. Maxmini sells some "bioniks" for orks, one of them being Tracks. You can build you own chassis using plasticard. Then just put the techmarine on top. Link to comment Share on other sites More sharing options...
ShinyRhino Posted May 10, 2010 Share Posted May 10, 2010 You might also look at an Epic Baneblade chassis. Thunderfire will be FAR too large for your purposes. You want it to still be able to fit on a 25-40mm base, otherwise it's too big to be an infantry model. Also take a look at Matchbox cars. You can often find cheap versions in the dollar store, which are old Sherman tanks of about the right size. Link to comment Share on other sites More sharing options...
Durus Posted May 10, 2010 Share Posted May 10, 2010 You might also look at an Epic Baneblade chassis. Thunderfire will be FAR too large for your purposes. You want it to still be able to fit on a 25-40mm base, otherwise it's too big to be an infantry model. While that might be true in a more competitive environment, it would be closer to the proportions of the example faol has posted. +edit+ Also just remembered this. Link to comment Share on other sites More sharing options...
crossbonesx11 Posted May 10, 2010 Share Posted May 10, 2010 New FW grot tanks. Link to comment Share on other sites More sharing options...
Piousservant Posted May 10, 2010 Share Posted May 10, 2010 A Forgeworld Cyclops might work, though I'm not entirely sure if it would be big enough. Link to comment Share on other sites More sharing options...
Bannus Posted May 11, 2010 Share Posted May 11, 2010 Looks like the actual model used in the conversion you posted is a Roco minitank - Sherman to be precise. It may be a little small for a Space Marine though, and not really "40K" enough. I would try a Tamiya 1/35th scale Goliath (WWII German remote-controlled full-tacked mine) - I think it would look really good. Link to comment Share on other sites More sharing options...
faol Posted May 14, 2010 Author Share Posted May 14, 2010 :) :cuss :) after hours of searching the world wide web it seems that the Tamiya 1/35th scale Goliath just doesn't exist any more if it does I can find it if anyone knows where to locate this model please let me know Good news everyone :D :tu: I finally found it after hours of searching I found it yay now I can finally get this conversion rolling Link to comment Share on other sites More sharing options...
