Sugamonster Posted May 11, 2010 Share Posted May 11, 2010 Hi all I posted on here that i was starting a sallamander army, i've bought myself a commend squand and plan on converting some of my dark angles (got way too many tac squads) and i was wondering if anyone could provide me with a paint scheme, im a little unsure about which paints too use Also some picts of your models would help to show me how to go about it. Thanks Pat :D Link to comment https://bolterandchainsword.com/topic/201103-sallies-painting-scheme/ Share on other sites More sharing options...
Bannus Posted May 11, 2010 Share Posted May 11, 2010 Check this out. Link to comment https://bolterandchainsword.com/topic/201103-sallies-painting-scheme/#findComment-2396699 Share on other sites More sharing options...
Sugamonster Posted May 15, 2010 Author Share Posted May 15, 2010 Thanks for the link, they are all very good painting ideas but i was looking for a more darker paint scheme, similar to the one shown in the lexicanum, can anyone tell me a paint similar to this one http://wh40k.lexicanum.com/wiki/Salamanders, im in AUS so im not sure if i can get Vagello colours Link to comment https://bolterandchainsword.com/topic/201103-sallies-painting-scheme/#findComment-2401147 Share on other sites More sharing options...
SCC Posted May 16, 2010 Share Posted May 16, 2010 Bannus' Sallies recipe is one of the darker ones out there, I think it looks pretty spiffy myself :blush: If it doesn't float your boat though you can always design the Sallie you'd like to paint in the SM Painter: And use the 'Which Paints Do I Need?' button to learn exactly what paints you'll need. As an example for the guy above the colour matcher says Foundry's Phlegm Green is the nearest match and it's almost spot on so that might be a colour to look into. If I were trying to get that crocodilian green in the illustrations at Lexicanium with just GW paints I'd try something like this: Undercoat: Black undercoat Basecoat: Orkhide Green Highlight 1: OG/Knarloc Green: 75/25 Highlight 2: OG/KG/: 50/50 Highlight 3: KG Badab Black wash Thraka Green Wash Re-touch final highlights if necessary I'd also experiment with colours like Catachan and Gretchin Green in the highlights to see how they work. If you want that mottled effect you'd probably look to stipple one or two of the highlight layers. I'd use a broad but short brush with nice stiff bristles and I'd load it with about the same amount of paint I'd use for drybrushing, maybe a touch more and stab at the model until I'd got that mottled effect. As for being in AU and getting Vallejo, it's more than possible I assure you, the dozens of VGC and VMC bottles on my desk right now attest to that. Whilst only a few stores stock them on the shelf lots will order them in for you and it's easy enough to mail order them, especially with the $AU as strong as it is right now. The same applies to Foundry, Privateer, Reaper and any other brand you care to mention. Link to comment https://bolterandchainsword.com/topic/201103-sallies-painting-scheme/#findComment-2401298 Share on other sites More sharing options...
Sugamonster Posted May 16, 2010 Author Share Posted May 16, 2010 Thanks a bunch, i think that i will have a test run with the scheme that you supplied in the space marine painter i'm gonna do a google search on the paints, the bitz store that i use had multiple brands of paints so i'll check them out Thanks Again Pat Link to comment https://bolterandchainsword.com/topic/201103-sallies-painting-scheme/#findComment-2401475 Share on other sites More sharing options...
