Vehicle Ramming and Disembarking
It does not mention anything special about passengers under tank shock/ramming so you use the basic rules. So yes, you could tank shock/ram 12" and then have the passengers hop out.
It is worth noting that it is pretty much impossible to get a 12" ram from a vehicle that can move 12". You have to move a full 12" to get a ram of that strength and you can't move farther. So that means the target has to be perfectly 12" away. Usually you will be a little less or a little more.
