jabba29 Posted May 12, 2010 Share Posted May 12, 2010 Hi,i am making a wolves company based on Egil Iron wolf.My enemy will be Blood angels army My lord will be TDA ,1 Axe + 1 storm shield or 2 axes (great visual with 2 axes but efficiency????) He will be followed by 4 wolf guard in terminator army for making a close combat group in Land raider. Wich weapons is the best for the group? I thought 1 TDA with Hammer+shield 2 TDA with twin wolf claws 1 TDA with assaut canon and wolf claws Do you think there is a better set for TDA? Link to comment https://bolterandchainsword.com/topic/201251-how-to-equip-lord-suit/ Share on other sites More sharing options...
Olgerth Istaarn Posted May 12, 2010 Share Posted May 12, 2010 You may want to consider Cyclone Missile Launcher instead of asscan. That way you can take two claws for an extra attack, or a stormbolter or a combi-weapon for an extra shot before assaulting (you can shoot your weapon IN ADDITION to the CML). Link to comment https://bolterandchainsword.com/topic/201251-how-to-equip-lord-suit/#findComment-2397579 Share on other sites More sharing options...
S. Bloodhowl Posted May 12, 2010 Share Posted May 12, 2010 I'd personally replace the hammer with a frost blade and give them meltabombs, or the asscan guy with a powerfist instead of wolf claw Link to comment https://bolterandchainsword.com/topic/201251-how-to-equip-lord-suit/#findComment-2397596 Share on other sites More sharing options...
Heimdall Skullcrusher Posted May 12, 2010 Share Posted May 12, 2010 You may want to consider Cyclone Missile Launcher instead of asscan. That way you can take two claws for an extra attack, or a stormbolter or a combi-weapon for an extra shot before assaulting (you can shoot your weapon IN ADDITION to the CML). This isn't entirely true, I dont believe you can fire a combi-weapon in addition to the CML, only a storm bolter as it specifically says so in the text Link to comment https://bolterandchainsword.com/topic/201251-how-to-equip-lord-suit/#findComment-2397634 Share on other sites More sharing options...
Darwinsfolly Posted May 12, 2010 Share Posted May 12, 2010 Just a quick note to point out, but you will need at least one more WG to get either the asscan or the CML. I don't know if you have 1 or more WG in PA attached to your other units but you need a minimum 5 Wolf Guard in a pack(they can all be split up though) before taking those heavy weapons. Like I said, I don't know if you have other WG in that unit that you are passing down to your troops, but I don't want you to accidentally cheat yourself and your opponent either. Link to comment https://bolterandchainsword.com/topic/201251-how-to-equip-lord-suit/#findComment-2397686 Share on other sites More sharing options...
Shieldwall Posted May 12, 2010 Share Posted May 12, 2010 It's cool looking an fluffy, however in terms of effectiveness.. I'd seperate the SS from the hammerboy, as the shieldguy is the one you'll want to put the nasty wound on to. Also, I'd rather go with a heavy flamer instead of the assault cannon, since you're mostly just gonna shoot once, which is after leaving the Raider. The asscannon's points are a waste for that. Double wolf claws is pretty heavy on points too, I'd rather give them a combiplasma and -melta. Link to comment https://bolterandchainsword.com/topic/201251-how-to-equip-lord-suit/#findComment-2397692 Share on other sites More sharing options...
