Azza007 Posted May 13, 2010 Share Posted May 13, 2010 Which configuration works best on a lone speeder? Only have the one for now and not sure what would be the best. Leaning towards the traditional heavy bolter and assault cannon combo or maybe multu-melta and assault cannon. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/ Share on other sites More sharing options...
stinkenheim Posted May 13, 2010 Share Posted May 13, 2010 ive recently been using the tornado but only because it compliments my army as it gives long range mobile fire support. the thing with landspeeders is they are versatile. if you need to deal with hordes they can, if you need to kill armour they can. it depends what you are lacking in your forces as to how to equip them. if you struggle against vehicles go the multi melta route as it fills a hole in your army. its hard to say which is better as they are both used for completely different roles Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2399085 Share on other sites More sharing options...
TiguriusX Posted May 13, 2010 Share Posted May 13, 2010 I like the typhoon missile launcher and multi-melta. Primary role is a mobile krak missile delivery system with an emergency melta shot on heavy armor. If I need to save some points I can keep the HB instead of the MM. The assault cannon is nice but the close ranges mean you have to expose your paper thin armor. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2399086 Share on other sites More sharing options...
hmk17 Posted May 13, 2010 Share Posted May 13, 2010 This is 5th ed. Missile Launchers are your friends. Typhoon Missile Launchers are sexy friends with benefits. Then add Heavy Bolter or Multi-Melta depending on if you are going troop hunting or tank hunting. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2399090 Share on other sites More sharing options...
MagneticFreak Posted May 14, 2010 Share Posted May 14, 2010 Recently, I've been using one with 2 MM's. I know, it seems redundant, but it increases the reliability of my anti-tank tactics. I'd love to use a typhoon, but the extra 40pts seems very expensive Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2399298 Share on other sites More sharing options...
Logan230 Posted May 14, 2010 Share Posted May 14, 2010 Typhoons are defiantly worth every point in my opinion, I use two in my list equipped with Missiles and MM. I use it just like TiguriusX. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2399308 Share on other sites More sharing options...
Azza007 Posted May 14, 2010 Author Share Posted May 14, 2010 Decided to go for the Typhoon with multi-melta. Packs an anti-armour punch and the frag rockets can deal with horde armies. Thanks for all the input. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2399768 Share on other sites More sharing options...
Godhead Posted May 15, 2010 Share Posted May 15, 2010 Typhoon and MM can provide 3 shots at ap3 (one is actually ap 1) that can Instant death T4. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2400480 Share on other sites More sharing options...
Ullr Direfang Posted May 15, 2010 Share Posted May 15, 2010 melta or missiles seem to work the best for us wolves, the extra fire power both provide against armor is really useful when you couple that with their movement abilitys Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2400761 Share on other sites More sharing options...
Zhukov Posted May 15, 2010 Share Posted May 15, 2010 Multimelta + Heavy Flamer. Relatively cheap, versatile and can possibly be used as semi suicide unit. (deepstriking). Multimelta on a fast/deepstriking platform is pretty nice; the Heavy flamer is cheap enough to take it. And indeed the Typhoon with MM or HB is very nice too; possibly better than the setup I suggested, but it depends on the list. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2400783 Share on other sites More sharing options...
Hotspur Posted May 15, 2010 Share Posted May 15, 2010 Typhoon all the way. Just switch up the MM and HB depending on what you're playing against. I've run a full squadron of Typhoons a couple of times in friendlies and they are deadly. Glad to see you went the Typhoon route; you'll be well pleased! Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2401109 Share on other sites More sharing options...
Grey Mage Posted May 15, 2010 Share Posted May 15, 2010 Recently, I've been using one with 2 MM's. I know, it seems redundant, but it increases the reliability of my anti-tank tactics. I'd love to use a typhoon, but the extra 40pts seems very expensive Only 10pts more than what your paying for the 2xMelta. Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2401219 Share on other sites More sharing options...
Wolf Guard Nostromo Posted May 16, 2010 Share Posted May 16, 2010 I agree with the comments on missile launchers... they really are the way forward. I'll also throw the cheap(ish) MM/HF config into the ring - a pair of these in reserve can be a nasty surprise for your opponent late in the day and won't break the bank. Paperthin armour at the relevant ranges though, as mentioned above. This isn't a config for a loner though, so stick with a ML if your going for just one... Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2401440 Share on other sites More sharing options...
Thylacine Posted May 16, 2010 Share Posted May 16, 2010 A month or two after 5th ed came out, all one heard was how Land Speeders were finished, but it seems at least here most people still use them. I took the wolves for a run yesterday, 1750 pts against a BA list and romped home with the Land Speeders taking out his Predators and a squad of troops. I mostly use the MM/HF but I do have a couple of AC/HB speeders, TiguriusX mentioned using MM/MM speeders and I could do this with one of mine, it would pack quite a punch. Anyone else running twin MM's on their speeders? Link to comment https://bolterandchainsword.com/topic/201366-landspeeder/#findComment-2401509 Share on other sites More sharing options...
