Malatox Posted May 17, 2010 Share Posted May 17, 2010 Hello all <_< First of all, I would like to clarify that I do posses the codex and I do possess the main rulebook, but I have let a freind borrow them because he is interested in starting ;). My main question is can a unit shoot a heavy weapon after disembarking from a Drop-pod? I looked at the codex and couldn't find a "no" to it. I'm asking this because I plan on Drop-podding in a tactical squad with a heavy weapon and if I can shoot a heavy weapon it could dictate where I place said Drop-pod... Anyway thank you for you time, and any replies to this :) Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/ Share on other sites More sharing options...
Astorath the Grim Posted May 17, 2010 Share Posted May 17, 2010 I can't say for sure..but I would think that since they are technically moving out of the pod that the heavy weapon wouldn't be able to fire that round. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402204 Share on other sites More sharing options...
Jim AMM realgenius Posted May 17, 2010 Share Posted May 17, 2010 Deep Striking transports count as moving cruising speed (pg 95). Disembarking from a moving vehicle means that the unit counts as moving (pg 67), so you can not fire heavy weapons. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402209 Share on other sites More sharing options...
Malatox Posted May 17, 2010 Author Share Posted May 17, 2010 Thanks for the fast reply <_<... The problem I have is that I've read the drop-pod entry and it says "the unit cannot assault" is all. It only states they disembark and I think that if a squad disembarks from a vehicle that hasn't moved the it may shoot as normal. Another point to back it up is that when a droppod is assaulted (in the oppenents turn straight after it coming down) it is counted as not moving. I'm puzzled is all and thought I'd ask all you clever clogs hear what to think ;) thanks again Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402211 Share on other sites More sharing options...
Olgerth Istaarn Posted May 17, 2010 Share Posted May 17, 2010 A disembark is a disembark. Unit counts as moving. Moving unit = no heavy weapons. Open and shut. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402214 Share on other sites More sharing options...
Astorath the Grim Posted May 17, 2010 Share Posted May 17, 2010 I don't use tac squads myself but I'd say these guys are right Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402218 Share on other sites More sharing options...
Malatox Posted May 17, 2010 Author Share Posted May 17, 2010 Fair enough, I'd have checked the book myself but as I said I don't have it with me right now... Thanks for the replies :) Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402219 Share on other sites More sharing options...
Bisa Posted May 17, 2010 Share Posted May 17, 2010 A disembark is a disembark. Unit counts as moving. Moving unit = no heavy weapons. Open and shut. Not quite, a disembark before the vehicle moves does not count. But we've already established here that the drop pod has moved. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402326 Share on other sites More sharing options...
ancient god Posted May 17, 2010 Share Posted May 17, 2010 A disembark is a disembark. Unit counts as moving. Moving unit = no heavy weapons. Open and shut. Not quite, a disembark before the vehicle moves does not count. But we've already established here that the drop pod has moved. They can move but they can't fire their heavy weapons as leaving a vehicle counts as movement anyway. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2402347 Share on other sites More sharing options...
igotsmeakabob!! Posted May 17, 2010 Share Posted May 17, 2010 A disembark is a disembark. Unit counts as moving. Moving unit = no heavy weapons. Open and shut. Not quite, a disembark before the vehicle moves does not count. But we've already established here that the drop pod has moved. They can move but they can't fire their heavy weapons as leaving a vehicle counts as movement anyway. I don't think this is correct. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2403060 Share on other sites More sharing options...
JamesI Posted May 17, 2010 Share Posted May 17, 2010 A disembark is a disembark. Unit counts as moving. Moving unit = no heavy weapons. Open and shut. Not quite, a disembark before the vehicle moves does not count. But we've already established here that the drop pod has moved. They can move but they can't fire their heavy weapons as leaving a vehicle counts as movement anyway. I don't think this is correct. It is correct. Disembarking from a vehicle, even one that hasn't moved, counts as movement for purposes of firing heavy weapons. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2403065 Share on other sites More sharing options...
igotsmeakabob!! Posted May 17, 2010 Share Posted May 17, 2010 As well as rapid fire, etc? Interesting. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2403073 Share on other sites More sharing options...
SamaNagol Posted May 17, 2010 Share Posted May 17, 2010 Disembarking is a form of movement done in the movement phase, so yes. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2403106 Share on other sites More sharing options...
Zeller Posted May 17, 2010 Share Posted May 17, 2010 You drop or leave a vehicle and your only options are to fire rapid fire weapons or assault weapons. Nuff said. Link to comment https://bolterandchainsword.com/topic/201639-drop-pods-and-heavy-weapons/#findComment-2403140 Share on other sites More sharing options...
