Land Raider question
Taeken
I'm wondering if this is possible. I have in front of me my soon to be magnetized Land Raider Redeemer/Crusader. Looking at the top of the hull I see 2 spots (besides the HB or AssC) and in the codex its worded "May take any of the following:" So does that mean I could take 2 options IE 2 Multimeltas? This is my first foray into Land Raider territory and I don't want to spend the time magnetizing & convirting anything if its not useable.
Thanks
https://bolterandchainsword.com/topic/201894-land-raider-question/
You can't have two multi-meltas. It goes by default with the assault cannon and then You CAN add multi-melta. The question is however which goes in which spot, because there are no general rules. Usually the LRC/LRR ir modelled with the AC in the front hatch and MM on the other on roof but nothing prevents You placing them in other order. And You actually don't have to magnetise hatches - they simply fill in the slots and can be removed while You transport the army. Also, if You don't glue it in You can always use the LR assault cannon on the Razorback.
As it was just pointed out to me...
It doesn't say that the sponson weapons have to be on the sponsons either :)
Thats true,but I am not sure that the top weapons get the 360 fire arc...though if they do...That would be nice.
Though I think that putting the two Flamestorm cannons on the top mounts,over the assault cannon,and putting a Multi melta and HK missile on the side slots would be utterly hilarious. Then again,If i could get one peice of gear from a different Race...I would totally put a Deathroller on the front of my Redeemer. I use it like a battering ram constantly anyways...that would just make it even more amusing.
