Fur Ball Posted May 21, 2010 Share Posted May 21, 2010 Has anyone used Army Painter Color Primers & Quickshade? What do you think of them? Also how complete did you do the faces? Did you paint in eyes before dipping or waited till after the dipping to finish it off? Link to comment Share on other sites More sharing options...
Saphos Posted May 22, 2010 Share Posted May 22, 2010 A forum search is your friend. :P I did not use the colour primers so far, but I had bad experience witht the white basecoat. But others had more positive experience. So ymmv. I very much like the Quickshade: http://www.bolterandchainsword.com/index.p...howtopic=199002 http://www.bolterandchainsword.com/index.p...howtopic=194045 I paint the eyes beforehand. I usually just paint the face in Bronzted Flesh and then apply a careful white drybrush. That is enough as you can see here: http://www.bolterandchainsword.com/index.p...p;#entry2364038 Link to comment Share on other sites More sharing options...
Cyrox Posted May 24, 2010 Share Posted May 24, 2010 I found that the sprays can come out quiote thick, so lots of thin coats are required rather than the way they do it on the tutorial Link to comment Share on other sites More sharing options...
igotsmeakabob!! Posted May 24, 2010 Share Posted May 24, 2010 I have had positive results with AP's Pure Red and Strong tone quickshade. I recommend them. Link to comment Share on other sites More sharing options...
brolthemighty Posted May 25, 2010 Share Posted May 25, 2010 So is the Quickshade actually a dip, or is it a wash? I had thought it was a wash? Link to comment Share on other sites More sharing options...
waitingtobedisciplined Posted May 25, 2010 Share Posted May 25, 2010 I use the sprays as a basecoat for my marines, thin, small and even coats work best, I've had no problem with them, however often washes separate over the coat, so adding a tiny amount of detergent, such as fairy liquid, to your washes should remove that problem though. Link to comment Share on other sites More sharing options...
Zanrian Posted May 25, 2010 Share Posted May 25, 2010 I'm using Army Painter primer (skeleton bone) and Quick Shade with a fine result. Link to comment Share on other sites More sharing options...
Zanrian Posted May 25, 2010 Share Posted May 25, 2010 So is the Quickshade actually a dip, or is it a wash? I had thought it was a wash? It's a dip. You can use it as a wash, IF you thin it alot. Link to comment Share on other sites More sharing options...
