River Troll=Nurgle Prince?
When my local store got the box I took a look at them and the manager told me that GW had accidently sent the boxs packed with 40k bases instead of the square fantasy bases. Well the bases that came in the box were terminator sized so I hope that gives you some idea on how big they are. Personally I think they are to small to be a DP, maybe a unit of terminators or spawn?
i had the same idea when i saw them in wd but i dont play nurgle.
if they are similar in size to the old ones i think they would need a bit of bulking to work as a demon prince or i would put some big terrain feature on the base so it makes them stand out more in the army.
looking at the pictures on the gw site i would make a guess and say they are in between a terminator and prince but would look ok as a small prince
best thing to do is look for them in displays in your local gw because its a new kit so they should be advertising them
I think the square base is 40mm across. Perhaps too small for a DP?....
You could make Nurglesque Oblits & Terms with them ;)
EDIT; maybe I'll mention Daemon things in the Daemon forum? :blink:
Beast of Nurgle and a Herald of Nurgle would make good use of the yummy River Trolls
