Grimtooth Posted May 25, 2010 Share Posted May 25, 2010 I am looking for an artist that is able to draw the following company badges: http://i150.photobucket.com/albums/s89/Grimtooth_photos/Current_great_company_icons.png and save them in one of the following file formats: * DXF compatible with AutoCAD version 2004 or earlier * DWG (DWG files compatible with AutoCAD version 2004 or earlier) * CDR (CorelDRAW) version 12 or earlier * AI (Adobe Illustrator) version CS or earlier * SVG * PDF I would like them to retain the size as the sample given above. PM to show me samples of your work. Mods if this request is unacceptable please delete. Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/ Share on other sites More sharing options...
Durus Posted May 25, 2010 Share Posted May 25, 2010 Just out of curiosity: What exactly do you mean by "draw"? Because if you want to use it with Auto CAD shouldn't it be at least in a vector based format? And if you don't want them in a higher resolution or as vector shape why do you need to recreate them at all? +edit+ By the way, CorelDraw should be able to generate vectors automatically with the black and white pic you have there. Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/#findComment-2411488 Share on other sites More sharing options...
Grimtooth Posted May 25, 2010 Author Share Posted May 25, 2010 Just out of curiosity: What exactly do you mean by "draw"? Because if you want to use it with Auto CAD shouldn't it be at least in a vector based format? And if you don't want them in a higher resolution or as vector shape why do you need to recreate them at all? +edit+ By the way, CorelDraw should be able to generate vectors automatically with the black and white pic you have there. I would like it in a vector shape so I could adjust size to what ever I need without losing resolution. The only reason I would like them redone is because currently the resolution is crap. If I used CorelDraw now on my existing, would they clean up enough? I really need a crisp image for my plans hence why I am looking for a redo of them. Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/#findComment-2411893 Share on other sites More sharing options...
Durus Posted May 25, 2010 Share Posted May 25, 2010 I haven't really played much with the feature, so I'm not quite sure. It might end up "pseudo pixelated" because it's such a small resolution, but I would still try it. Maybe you could ask somebody in a copy shop to try it out for you if you don't have CD yourself. Some shops could probably trace the image for you as well(for outrageous prices of course). I only have photoshop and If I'm not mistaken I could export paths as an Illustrator file. But I don't have a lot of time at the moment, so unless you need one of the Icons specifically instead of the whole sheet I probably won't be able to help you. And I never exported an AI file with photoshop so I can't guarantee that it will work. On the other hand I could give you the image in any resolution you need once I had traced them. I just though you might want to use the images with a milling machine or a plotter or something like that so that a vector based output would be required. Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/#findComment-2412223 Share on other sites More sharing options...
Red Fury Posted May 26, 2010 Share Posted May 26, 2010 I could vectorize it for cutting but you wouldn't be able to resize it. You need to resize it first and then vectorize it to create a drawing to write your g-code from. I only run bob-cad here but my neighbor runs correll-draw and sign-lab and one from adobe too I think. What is the end goal here though? Do you want them cut out? or is it just to have the images with a higher res? -Fury Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/#findComment-2412394 Share on other sites More sharing options...
Grimtooth Posted May 26, 2010 Author Share Posted May 26, 2010 I have a place that might be able to laser cut styrene for me and need to send them a clean image in one of those formats to see if they can even do it first before I move on. Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/#findComment-2412541 Share on other sites More sharing options...
Red Fury Posted May 26, 2010 Share Posted May 26, 2010 My neighbor has two laser cncs, I run a router cnc. I think he charges something like 40 buck to cut a 4x4 of anything. I'm in southern California so shipping wouldn't be bad. Let me know if you want me to ask him. -Fury Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/#findComment-2413168 Share on other sites More sharing options...
Zode Posted May 26, 2010 Share Posted May 26, 2010 Do you have access to AutoCAD? If so just import the file into a drawing, blow it way up and then trace the outlines with a line tool. That's what my friend and I have done before and it works great, you don't even need to be a good artist. Link to comment https://bolterandchainsword.com/topic/202366-looking-for-an-artist/#findComment-2413307 Share on other sites More sharing options...
