Raulmichile Posted May 25, 2010 Share Posted May 25, 2010 By the rules I think you can buy Melta bombs to Character and WG termies. But is this correct? I wanted to ask this for a long time. Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/ Share on other sites More sharing options...
CainTheHunter Posted May 25, 2010 Share Posted May 25, 2010 Yes, and also You can have them on Wolf scouts and Swiftclaws. Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2411900 Share on other sites More sharing options...
Vassakov Posted May 25, 2010 Share Posted May 25, 2010 By the rules I think you can buy Melta bombs to Character and WG termies. But is this correct? I wanted to ask this for a long time. By the rules, you most certainly can. Is it technically fluffy... perhaps not. But hey, we're the Son's of Russ - there's probably a commandmant in the Codex: Astartes somewhere that says "Thou shalt not tape Meltabombs to thine Breastplate" that we've ignored! :) Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2412002 Share on other sites More sharing options...
morehardcore Posted May 26, 2010 Share Posted May 26, 2010 i dont think we would have to tape them to our armor after all all of the gernade slots are taken up with tankards and minature kegs, same way we always use drops pods instead of teleporters, u cant fit beer in a teleporter. but realisticly is rules wise prolly a error but watever fluffwise tho we are space wolves we have our codex: russ, its the codex astartes but everything is reversed (at least wen ur drunk but then again wat proper wolf isnt) for example codex astartes: thou shalt not sleep with bolters babes light beer is a privilege once a week only thou shalt not personalize thy bolter thou shalt not pimp out thy rhino codex russ: thou shalt sleep with as many bolter babes as possible heavy beer is a right, every night at least 100 glasses should be consumed (or as high as u can count once ur smashed) thou shalt personalize thy bolter wolf skulls and gold plating recommended thou shalt pimp out thy rhino- recommended items: rims kegs botler rounds kegs paintings kegs etc (kegs) Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2412406 Share on other sites More sharing options...
Sarapham Posted May 26, 2010 Share Posted May 26, 2010 It just shows we are the most awesome with TDA, including old Njal who is the only one who can wield a Bolt pistol in TDA. Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2412849 Share on other sites More sharing options...
Vlk Posted May 26, 2010 Share Posted May 26, 2010 i dont think we would have to tape them to our armor after all all of the gernade slots are taken up with tankards and minature kegs, same way we always use drops pods instead of teleporters, u cant fit beer in a teleporter. but realisticly is rules wise prolly a error but watever fluffwise tho we are space wolves we have our codex: russ, its the codex astartes but everything is reversed (at least wen ur drunk but then again wat proper wolf isnt) for example codex astartes: thou shalt not sleep with bolters babes light beer is a privilege once a week only thou shalt not personalize thy bolter thou shalt not pimp out thy rhino codex russ: thou shalt sleep with as many bolter babes as possible heavy beer is a right, every night at least 100 glasses should be consumed (or as high as u can count once ur smashed) thou shalt personalize thy bolter wolf skulls and gold plating recommended thou shalt pimp out thy rhino- recommended items: rims kegs botler rounds kegs paintings kegs etc (kegs) All those kegs gave me a very interesting conversion idea... One day, I'm going to field a deadly squad of Wolf Guard Terminators - each with his own keg of ale! Terminaletors for the win! Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2412907 Share on other sites More sharing options...
Marmande Posted May 26, 2010 Share Posted May 26, 2010 You can take Melta Bombs with SW Terminators, but don't forget that a Chainfist works, too. ;) Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2412937 Share on other sites More sharing options...
spjaco Posted May 26, 2010 Share Posted May 26, 2010 Could it be the other chapters are feeling "ALE-inatied"? Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2412964 Share on other sites More sharing options...
hmk17 Posted May 26, 2010 Share Posted May 26, 2010 i dont think we would have to tape them to our armor after all all of the gernade slots are taken up with tankards and minature kegs, same way we always use drops pods instead of teleporters, u cant fit beer in a teleporter. but realisticly is rules wise prolly a error but watever fluffwise tho we are space wolves we have our codex: russ, its the codex astartes but everything is reversed (at least wen ur drunk but then again wat proper wolf isnt) for example codex astartes: thou shalt not sleep with bolters babes light beer is a privilege once a week only thou shalt not personalize thy bolter thou shalt not pimp out thy rhino codex russ: thou shalt sleep with as many bolter babes as possible heavy beer is a right, every night at least 100 glasses should be consumed (or as high as u can count once ur smashed) thou shalt personalize thy bolter wolf skulls and gold plating recommended thou shalt pimp out thy rhino- recommended items: rims kegs botler rounds kegs paintings kegs etc (kegs) Its not that you can't fit kegs in a teleporter, its that the kegs would sometimes re-materialize empty... As to the OP: WL, RP, WP, WGBL, WG, Scouts, LW, TWC, and SCB all can take melta bombs. Link to comment https://bolterandchainsword.com/topic/202418-is-it-proper/#findComment-2413484 Share on other sites More sharing options...
