MuGGzy Posted May 25, 2010 Share Posted May 25, 2010 I wanted to see what other people have come up with to represent the Frag Canon? Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/ Share on other sites More sharing options...
igotsmeakabob!! Posted May 25, 2010 Share Posted May 25, 2010 I cut off most of the barrel on a Twin-linked Autocannon. I have a pic of it somewhere.. http://img208.imageshack.us/img208/3101/img0343zn.jpg Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412068 Share on other sites More sharing options...
Morticon Posted May 25, 2010 Share Posted May 25, 2010 PERFECT !!! :huh: Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412076 Share on other sites More sharing options...
igotsmeakabob!! Posted May 25, 2010 Share Posted May 25, 2010 I drilled out most of the barrels, it looks pretty good. Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412082 Share on other sites More sharing options...
Angelus Mortifer Posted May 25, 2010 Share Posted May 25, 2010 I did similar to igotsmeakabob!! by chopping off the T/L LC from the new Ven Dread kit, then adding one of the double ammo drums from the Aegis Line Quad Gun. If I had more time I would have shaved it down a bit so it didn't widen the Dread profile as much as it does, but it worked pretty well. http://i741.photobucket.com/albums/xx54/SebJones_photos/Blood%20Angels/DreadFragCannon1-1.jpg (opposite profile) http://i741.photobucket.com/albums/xx54/SebJones_photos/Blood%20Angels/DreadFragCannon2.jpg Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412181 Share on other sites More sharing options...
4RC71C FOXX Posted May 25, 2010 Share Posted May 25, 2010 I am so inspired!! I'm going to have to make my own now!! :-) what a shame :-P One question though, with the LC does it require alot of drilling out of the barrel? or is it hollow? If it does need drilling what would be the best way to do so? Tool-wise? FOXX Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412294 Share on other sites More sharing options...
Angelus Mortifer Posted May 25, 2010 Share Posted May 25, 2010 The standard Dread LC has the barrels in 2 halves that glue together, and which are designed hollow. So if you used that you would only need to cut it to the length you wanted. The Ven Dread version sadly isn't hollow, and I had to borrow a mate's hand drill with 3/32 bit (you could probably go the next size up but it doesn't leave a lot of room for error, so I played it a bit safer). The FW Autocannons chopped down do look pretty cool though (hmmm, maybe if I run 2 Frag Cannons.... :devil: ) Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412313 Share on other sites More sharing options...
Gridlocked Posted May 25, 2010 Share Posted May 25, 2010 I was thinking mucking around with a Grottzoka. Big blunderbuss kinda deal. Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412357 Share on other sites More sharing options...
4RC71C FOXX Posted May 26, 2010 Share Posted May 26, 2010 Thanks Angelus Mortifer :-) . FOXX Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412402 Share on other sites More sharing options...
Angelus Mortifer Posted May 26, 2010 Share Posted May 26, 2010 Thanks Angelus Mortifer :-) . FOXX No worries mate :P Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412410 Share on other sites More sharing options...
Gridlocked Posted May 26, 2010 Share Posted May 26, 2010 Oh yeah that dread of yours also looks killer Angelus. Love the pretties stuck to it. Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412412 Share on other sites More sharing options...
wookielips Posted May 26, 2010 Share Posted May 26, 2010 I was thinking mucking around with a Grottzoka. Big blunderbuss kinda deal. i was thinking of a dread assault cannon with a vindi nozzle, widened on the end. its meant to be an extremely short-ranged storm of shrapnel, the smaller barrels belie this definition of the guns build and purpose, imo. Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2412413 Share on other sites More sharing options...
MuGGzy Posted May 26, 2010 Author Share Posted May 26, 2010 I was thinking mucking around with a Grottzoka. Big blunderbuss kinda deal. i was thinking of a dread assault cannon with a vindi nozzle, widened on the end. its meant to be an extremely short-ranged storm of shrapnel, the smaller barrels belie this definition of the guns build and purpose, imo. I am looking at using some small guage PVC pipe and setting up a big side by side or 4 tube shotgun looking deal. When I read the description I pictured a giant double barreled .12 guage shotgun anyways. Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2413219 Share on other sites More sharing options...
wookielips Posted May 26, 2010 Share Posted May 26, 2010 if you made a double barreled 12 gauge look, that worked with cracking barrels for reload, it would be the coolest conversion of all time Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2413276 Share on other sites More sharing options...
Brother_Dan'l Posted May 26, 2010 Share Posted May 26, 2010 But do you go with over-under or side by side? ;) I used the Lascannon for my first and the FW autocannons for the second. The FW looks "realer", but is a real bitch to drill out enough that the bore looks huge to match the fluff. For the third :) I'm going to try plastic with some sort of magazine system, probably spare drums from the IG heavy weapons box. http://i207.photobucket.com/albums/bb219/Brother_Daniel/FuriosoAlpha3.jpg edit: added photo Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2413292 Share on other sites More sharing options...
MuGGzy Posted May 27, 2010 Author Share Posted May 27, 2010 I got the pipe last night and settled on a Tri Barrel shotgun looking setup, not sure how I will represent the "feed" yet though. Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2414796 Share on other sites More sharing options...
Grazcruzk Posted May 27, 2010 Share Posted May 27, 2010 I used a missile launcher arm as a base and a few chopped down las cannons for the barrels. merged the exhaust on the ml into two larger ones. I guess don't have a shot of that arm specifically but here is what I've got. http://i6.photobucket.com/albums/y221/loki114/warhammer%20stuff/IMG_1460.jpg Link to comment https://bolterandchainsword.com/topic/202428-frag-canon/#findComment-2415051 Share on other sites More sharing options...
