Two Rules Questions
Panzerkopf
First question, does a Celestian Retinue for a Sororitas Heroine count towards the army's Faith Point total? They're a Faithful unit, but they count as being part of the same slot as the Heroine.
Second question, can the Priest from Codex: Imperial Guard unlock Arco-Flagellants? To be rules-lawyery, it shouldn't since the guy in IG is a "Ministorum Preacher" while the guy from Codex: WH is merely a "Priest", and the entry for Arco-Flagellants states that a "Priest" is needed to take them in your army. However, the part of me that follows common sense says that they're the same freakin' thing so either one should count. I'm running Guard with allied OH by the way.
https://bolterandchainsword.com/topic/202456-two-rules-questions/
First question: Yes :devil: The Celestian VSS is a faithful character, and as such adds to the Faith pool regardless of what slot she is occupying.
Second question: No. As per the DH and WH FAQs which clarified that an Inquisitor from one Codex does not unlock assassins in the other (though why you need to do that really unless you're trying to ally both DH and WH to the same SM or IG army I have no idea), and the WH further clarifies this point on page 3:
Do Arco-Flagellants require a Witch Hunter
Priest to be fielded or can an Imperial Guard
Priest fulfill the requirement?
A. Yes – the Priest referred to is the Priest in the
Witch Hunters Codex.
This makes it fairly clear IMO.
First question: Yes :rolleyes: The Celestian VSS is a faithful character, and as such adds to the Faith pool regardless of what slot she is occupying.
The answer is indeed yes but not because of the VSS. Celestians are faithful period, the only real reason for picking a vet is the slightly better stat line and the fact that you can access the inventory.
So, a celestian retinue will provide FP's towards the faith pool regardless of the presence of a Vet Supe in the retinue squad.
Really? *checks* Hunh, gold star for ArmouredWing! I always just upgrade every Sister Superior to a Veteran on general principle, so I missed that tidbit... that and not having used Celestians a lot myself that'll do that. Glad to see it's the same answer though ;)
Really? *checks* Hunh, gold star for ArmouredWing! I always just upgrade every Sister Superior to a Veteran on general principle, so I missed that tidbit... that and not having used Celestians a lot myself that'll do that. Glad to see it's the same answer though B)
...and the same rule applies for Seraphim as well although in their case the VSS also acts as an imagifier and a cheap one at that.
