MogLord Posted May 26, 2010 Share Posted May 26, 2010 Hi, i ´m searching for the ideal size of my three equaly configured grey hunter packs, know i wanted the opinion of all the wolves out there in (cyber-)space! 7 Grey hunters -Melter -wolf standard -Mark -Rhino each of the packs get a WG-leader with P-fist and Combi-Melter. Do you think the size of the packs is to small or should i devide them in uneven numbers (p.e. 10-6-5). Thanks in advance for imput! Yours Mog Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/ Share on other sites More sharing options...
GeoWolf Posted May 26, 2010 Share Posted May 26, 2010 I usually try to field 10 in my packs, unless I'm going for a WG or they are in a Razorback. If you are going to go with smaller packs, I would look into the razorbacks, so you are not wasting potential transport space and you gain another weapon. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413206 Share on other sites More sharing options...
Logan230 Posted May 26, 2010 Share Posted May 26, 2010 Hi, i ´m searching for the ideal size of my three equaly configured grey hunter packs, know i wanted the opinion of all the wolves out there in (cyber-)space! 7 Grey hunters -Melter -wolf standard -Mark -Rhino each of the packs get a WG-leader with P-fist and Combi-Melter. Do you think the size of the packs is to small or should i devide them in uneven numbers (p.e. 10-6-5). Thanks in advance for imput! Yours Mog Well, I dont know about the Long Fangs around here, but I am not quite sure what you are asking for. What are they supposed to do, how are they getting around...? a little more info about the list they will be apart of would be cool to. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413209 Share on other sites More sharing options...
Blarmb Posted May 26, 2010 Share Posted May 26, 2010 Generally speaking Grey Hunter packs show up in one of the following sizes: 1) 5 + Wolf Guard in a Razorback 2) 9 + Wolf Guard in a Rhino/Drop Pod 3) 10 in a Rhino/Drop Pod On occasion other configurations will show up, such as a full pack with WG and a IC in a Land Raider or some footslogging setup but those aren't nearly as common. I'm personally somewhat partial to option #1 because I love the extra heavy weapon, however that really is a matter of taste. From what I've seen the Rhino squads are the more popular than the Razorback squads, especially option #2. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413241 Share on other sites More sharing options...
RunningWolfFenris Posted May 26, 2010 Share Posted May 26, 2010 I like using 10 GHs so I can get the extra special weapon usually. WG doesn't count towards getting the extra weapon so I try and field squads of 10 unless there's another factor at play Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413333 Share on other sites More sharing options...
Grimtooth Posted May 26, 2010 Share Posted May 26, 2010 I am always fielding 10 with two special weapons. I see no point in ever adding WG to GH squads for a one-time combi shot when I can have 2 special weapon shots all game, or however long the unit can keep them alive. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413361 Share on other sites More sharing options...
RunningWolfFenris Posted May 26, 2010 Share Posted May 26, 2010 I am always fielding 10 with two special weapons. I see no point in ever adding WG to GH squads for a one-time combi shot when I can have 2 special weapon shots all game, or however long the unit can keep them alive. Wingapo! I understand the reasoning (better Ld, etc) for using WG but for the most part, I'm perfectly content to use a squad of ten with 2 special weapons. It's such a bargain and seems to be a little more efficient too. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413369 Share on other sites More sharing options...
ChapniK Posted May 26, 2010 Share Posted May 26, 2010 Hi, i ´m searching for the ideal size of my three equaly configured grey hunter packs, know i wanted the opinion of all the wolves out there in (cyber-)space! 7 Grey hunters -Melter -wolf standard -Mark -Rhino each of the packs get a WG-leader with P-fist and Combi-Melter. Do you think the size of the packs is to small or should i devide them in uneven numbers (p.e. 10-6-5). Thanks in advance for imput! Yours Mog Thats almost the same setup that i use but i have a grey hunter with a power sword/axe. There still pretty cheap compared to other marine core choice, but have all the assaulty goodness of a assault squad and almost the firepower of a tactical squad. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413373 Share on other sites More sharing options...
Blarmb Posted May 26, 2010 Share Posted May 26, 2010 I am always fielding 10 with two special weapons. I see no point in ever adding WG to GH squads for a one-time combi shot when I can have 2 special weapon shots all game, or however long the unit can keep them alive. Wingapo! I understand the reasoning (better Ld, etc) for using WG but for the most part, I'm perfectly content to use a squad of ten with 2 special weapons. It's such a bargain and seems to be a little more efficient too. I like the Razorback/WG combo, I think it has a lot of merit. You're paying same points (75) as you would for the five guys to fill out to the 2nd special weapon and getting a Heavy weapon instead. Or in the case of the ever popular Las/Plas razorback a heavy weapon and a twin-linked special weapon. You lose out on body count somewhat, but potentially gain a fair amount firepower. Also since you're paying down the cost of your Transport at the same time you buy that weapon, you actually make up a bit of your body count in your next squad. Given the same choice of 1st special weapon you're going to be paying 12 points less for a heavy weapon razorback + 5 guys + WG /w Combi weapon than you are for a 10 man GH squad in a rhino. If you're buying the squad a special close combat weapon it becomes favorable, since the WG costs 3 points more but has CCWs that are 5 points cheaper, netting you +3 points. Works great with a power fist since they have 2 attacks base. That extra 3 point savings puts it at the 15 point difference needed to pay off the 1st body in your next squad. Meaning you're really only down 3 bodies from a 10-man squad, with a good boost to firepower in exchange. They're both fine options, but I really like what I can squeeze out of a leaner unit led by a WG. Though at higher points I'd probably try to get the best of both worlds and run 3 Razorback Squads and 2 Rhino Squads, or 4 and 2. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413385 Share on other sites More sharing options...
DV8 Posted May 26, 2010 Share Posted May 26, 2010 As a personal preference I tend to equip my squads in as versatile a manner as possible. This means my typical pack: 9 Grey Hunters, Meltagun, Rhino Wolf Guard Pack Leader, Power Fist, Combi-Flamer I run three of these packs at 1000 or 1500 points, with 2 of them dropped to 8-man to fit a Rune Priest in each. My fourth Grey Hunter pack is: 10 Grey Hunters, 2 Meltaguns, Drop Pod And they act as my alpha strike unit to knock out serious threats early in the game, or to run as a suicide-distraction for my opponent while the rest of my army advances up. DV8 Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413489 Share on other sites More sharing options...
Simo429 Posted May 26, 2010 Share Posted May 26, 2010 i always run 10 for the extra special weapon 2 grey hunters toting meltas is a powerful unit Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413501 Share on other sites More sharing options...
Gen. Confusion Posted May 27, 2010 Share Posted May 27, 2010 I almost always run my Grey Hunters as follows. 9 grey hunters, meltagun, rhino, wolf guard with powerfist and combi-melta. Nice cheap unit that can get any job done. If I have any extra points I will sometimes add in a power weapon, mark of the wolfin and/or wolf standard. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413783 Share on other sites More sharing options...
Roland Durendal Posted May 27, 2010 Share Posted May 27, 2010 I run 2 different types: For my normal lists, from 1000-2500 pts I run: 2 Squads of: 10X GH, 2X Melta, MotW, Wolf Banner, PW, Rhino 1 Squad of: 10X GH, 2X Melta, MotW, PF, Rhino At 500pts though, I typically run: 2X Squads of: 5X GH, 1XM, MotW, PW, Razorback Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413894 Share on other sites More sharing options...
Marmande Posted May 27, 2010 Share Posted May 27, 2010 10 Grey Hunters with double Melta/Plasma, a banner, MotW, and a rhino. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413920 Share on other sites More sharing options...
JaegerAD Posted May 27, 2010 Share Posted May 27, 2010 i run 2 types in 1500 pts: 9 GH Melta, MotW, Banner Rhino (2 packs for attack) 5 GH Melta, MotW, Banner, Rhino ( protekt my objektive) both packs with WG, PF Kombi-Melter Works fine with me Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2413950 Share on other sites More sharing options...
Hotspur Posted May 27, 2010 Share Posted May 27, 2010 10 man GH squad in a rhino is how I usually field mine. That way, they can get the 2-for-1 special weapon. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2414410 Share on other sites More sharing options...
wolf2.3 Posted May 27, 2010 Share Posted May 27, 2010 I'm going to break the trend. I run 10 footsloggers (shock, horror :D ) with a wolf guard and powerfist. I either take twin melta or plasma. No transports though as I support them with other fast stuff, belive it or not it works well. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2414462 Share on other sites More sharing options...
chaplain belisarius Posted May 27, 2010 Share Posted May 27, 2010 10 grey hunters-powerfist, 2 meltaguns in a rhino. best squad in the game!:) Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2414508 Share on other sites More sharing options...
Hotspur Posted May 27, 2010 Share Posted May 27, 2010 Since we're getting into the nitty gritty :) , here' my standard GH squad: 10 Grey Hunters- 240pts. 2x Meltagun Powerfist Standard MotW Rhino Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2414518 Share on other sites More sharing options...
pucadubh Posted May 27, 2010 Share Posted May 27, 2010 I run 2 GH units as assault squads in my Thunderwolf army. Both squads have 8 GHs - meltagun, standard & mark in a Rhino with extra armour. Add to that a WGPL with combi-melta and powerfist and then a Rune Priest. RP in squad 1 has Chooser, Living Lightning and Murderous Hurricane (or Tempests Wrath) RP in squad 2 has Jaws & Storm Caller. RP2 is legend as on game 2 with the list he took out a Nightbringer (even a 6 on a d6 is a 16% chance to instantly change a game) and Storm Caller in a Rhino changes the save bubble from 6" to about 9", measure from anywhere on the hull ;) I have a 3rd home defence GH unit and that is 10x GH - 2 plasmagun, standard, mark with a TDA WGPL with combi melta and chainfist (no more probs with turn 1 drop pod Ironclads). This list has served me well and while there are TW Lords or Batlle Leaders, TWC, FWs, Lone Wolves, Long Fangs and extra heavies depending on the points, this is my core and my GHs always give a good account of themselves. Link to comment https://bolterandchainsword.com/topic/202517-grey-hunter-pack-size/#findComment-2414591 Share on other sites More sharing options...
