Heimdall Skullcrusher Posted May 27, 2010 Share Posted May 27, 2010 I know that in the FAQ it says Canis gets the Wolfkin ability (re-roll failed leadership within 12"). Does this mean that a Wolf Lord or Battle Leader would get this as well when equiped with a Thunderwolf mount? I'm thinking no as it doesn't say so but figured I'd ask anyways. And if so, if they were joined with the wolves, would any morale tests be made with their leadership and re-rolled if failed? Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/ Share on other sites More sharing options...
Requiem of the Wolf Posted May 27, 2010 Share Posted May 27, 2010 I know that in the FAQ it says Canis gets the Wolfkin ability (re-roll failed leadership within 12"). Does this mean that a Wolf Lord or Battle Leader would get this as well when equiped with a Thunderwolf mount? I'm thinking no as it doesn't say so but figured I'd ask anyways. And if so, if they were joined with the wolves, would any morale tests be made with their leadership and re-rolled if failed? wolfkin is something that TWC get,so I would assume that a char mounted on it would as well. that is the reroll failed leadership. You would need saga of the Wolf kin to give them the leadership. Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/#findComment-2415037 Share on other sites More sharing options...
Godhead Posted May 27, 2010 Share Posted May 27, 2010 pretty sure the wolkin rule is listed under the TWM section. Lord on a TWM should give those wolves ld 10. Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/#findComment-2415044 Share on other sites More sharing options...
Heimdall Skullcrusher Posted May 27, 2010 Author Share Posted May 27, 2010 But if he was joined with them, you would use his leadership (being the highest) for all moral tests Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/#findComment-2415046 Share on other sites More sharing options...
TiguriusX Posted May 27, 2010 Share Posted May 27, 2010 The wolfkin rule only applies to TWC (the elite unit) HQs have a TWM and the wolfkin rule is not listed Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/#findComment-2415047 Share on other sites More sharing options...
stinkenheim Posted May 27, 2010 Share Posted May 27, 2010 no. the TWM entry specifically states all the bonuses and penalties a model has, 'Wolfkin' isn't listed so it is wrong to assume they have it. Canis has 'Lord of the Wolfkin' as a special rule spelled out in his entry, it is one reason to take him over a WGBL. TWC have 'Wolfkin' as a unit special rule becuse they have bonded on a physical and spiritual level with their mount. Saga of the Wolfkin merely increases the base ld of wolves it doesn't offer any re-rolls. If the IC on TWM joined a unit of wolves they would test on his ld 10 (as it is the highest in the unit) basically you want to re-roll the tests take canis or TWC, you want a real killy guy take a lord on TWM Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/#findComment-2415053 Share on other sites More sharing options...
Godhead Posted May 27, 2010 Share Posted May 27, 2010 Yep, I was wrong, the wolkin entry was indeed under the TWC description. Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/#findComment-2415057 Share on other sites More sharing options...
Requiem of the Wolf Posted May 27, 2010 Share Posted May 27, 2010 Yep, I was wrong, the wolkin entry was indeed under the TWC description. Hmmm...I stand corrected...ah well Take a WL on TWM with SS,FB, and two Fenrisian Wolves as Wargear,with Oath of Wolf kin.A Single TWC with SS,TH,and then 15 Fenrisian Wolves. boom...Leadership 10,rerolls on Leadership,Plenty of fast acting chompy wolves and amusements. Link to comment https://bolterandchainsword.com/topic/202645-ic-with-thunderwolf-leading-fenrisian-wolves/#findComment-2415091 Share on other sites More sharing options...
