JMac Posted May 30, 2010 Share Posted May 30, 2010 When a terminator take a combi-bolter, does he then lose the storm bolter and get a boltgun traits? Or does he get the storm bolter traits and also the combi-weapon? Link to comment https://bolterandchainsword.com/topic/202875-term-combi-bolters/ Share on other sites More sharing options...
TiguriusX Posted May 30, 2010 Share Posted May 30, 2010 A combi-bolter is not a storm bolter. Different rules and number of shots etc. Read p. 57 of your SW codex closely. The combi-bolter behaves like a regular bolter. Due to TDA relentless rules the final difference is a combi-bolter can only rapid fire up to 12" instead of 24" of a SB. Link to comment https://bolterandchainsword.com/topic/202875-term-combi-bolters/#findComment-2417890 Share on other sites More sharing options...
JMac Posted May 30, 2010 Author Share Posted May 30, 2010 Thats exactly what i thought. Thanks for taking time to answer my noob question :P Link to comment https://bolterandchainsword.com/topic/202875-term-combi-bolters/#findComment-2417894 Share on other sites More sharing options...
TiguriusX Posted May 30, 2010 Share Posted May 30, 2010 No problem pup. Go make the wolves proud Link to comment https://bolterandchainsword.com/topic/202875-term-combi-bolters/#findComment-2417901 Share on other sites More sharing options...
Valerian Posted May 31, 2010 Share Posted May 31, 2010 A combi-bolter is not a storm bolter. Different rules and number of shots etc. Read p. 57 of your SW codex closely. The combi-bolter behaves like a regular bolter. Due to TDA relentless rules the final difference is a combi-bolter can only rapid fire up to 12" instead of 24" of a SB. You can still chose to take a single shot up to 24" with your Combi-Bolter (since Relentless lets you fire as if stationary), so you are only sacrificing the second shot between 12-24" in order to get the added one-time special weapon shot of your choice for the game. Very good deal if you are using a transport (Drop Pod, Land Raider) to get within 12" of the enemy anyway, in which case you really aren't sacrificing anything. Valerian Link to comment https://bolterandchainsword.com/topic/202875-term-combi-bolters/#findComment-2419328 Share on other sites More sharing options...
Grey Mage Posted May 31, 2010 Share Posted May 31, 2010 Yep, and thankfully you can assault after rapid firing in TDA, so your not hobbling yourself there either. Link to comment https://bolterandchainsword.com/topic/202875-term-combi-bolters/#findComment-2419334 Share on other sites More sharing options...
