The Unknown Father Posted May 31, 2010 Share Posted May 31, 2010 The topic is easy, the scout squad box haven´t got any power fist and just using a tactic marine power fist doesn´t go well any suggestion? Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/ Share on other sites More sharing options...
Meatman Posted May 31, 2010 Share Posted May 31, 2010 The assault marine powerfist but leave the shoulder pad off. Fits perfectly. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2418588 Share on other sites More sharing options...
GumbaFish Posted May 31, 2010 Share Posted May 31, 2010 I believe that the cadian command squad comes with a powerfist that should fit nicely on a scout. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2418609 Share on other sites More sharing options...
Saphos Posted May 31, 2010 Share Posted May 31, 2010 I use the old plastic powerfists. http://www.flickr.com/photos/cplhicks/4615625491/ But probably hard to come by for you. The other suggestions would have been mine, too otherwise. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2418666 Share on other sites More sharing options...
Meltaface Posted May 31, 2010 Share Posted May 31, 2010 I use AoBR terminator fists for my scouts. I'll try to get a picture later. Edit: Forgot I already had a wip picture. http://img241.imageshack.us/img241/4563/img0013f.th.jpg Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2418667 Share on other sites More sharing options...
pingo Posted May 31, 2010 Share Posted May 31, 2010 I believe that the cadian command squad comes with a powerfist that should fit nicely on a scout. This. Anything else is too big and (in my opinion) looks silly. Like one of those big foam hands at sporting events. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2418680 Share on other sites More sharing options...
Wicksy Posted June 1, 2010 Share Posted June 1, 2010 I believe that the cadian command squad comes with a powerfist that should fit nicely on a scout. My scout squad sgt thinks so :) Yeah, cadian command squad jobbie. Should be a few floating around as not many IG players use fists on scuds. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2420431 Share on other sites More sharing options...
Koyote Posted June 1, 2010 Share Posted June 1, 2010 I like the look of a power armored Space Marine power fist on a Scout. The shoulder piece on the power fist bit is just about the same size as a Scout shoulder pad. The fist a bit large, but then again, so are the Scout pistols. Besides, this is science fiction so why not go crazy? http://i72.photobucket.com/albums/i200/10011970/PFscout.jpg Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2420750 Share on other sites More sharing options...
Gurth Posted June 2, 2010 Share Posted June 2, 2010 How to get a power fist into scouts? Say "Bend over!" ^_^ Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2421058 Share on other sites More sharing options...
Tanhausen Posted June 2, 2010 Share Posted June 2, 2010 How to get a power fist into scouts? Say "Bend over!" ;) BAD joke :P xDDDDDD Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2421750 Share on other sites More sharing options...
ArcticFox Posted June 3, 2010 Share Posted June 3, 2010 Heh I was thinking that same thing... The old old old Space Marine powerfist that came in the original RT boxes are considerably smaller than the current PF. It h as the integrated shoulder pad but even that is way smaller then the current ones as well. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2422868 Share on other sites More sharing options...
Gurth Posted June 4, 2010 Share Posted June 4, 2010 To make the joke even worse than you all seem to consider it already, in my Space Marines army, all power fists are brown in colour. But this is just because it fits the army theme :P Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2423578 Share on other sites More sharing options...
averykess Posted June 4, 2010 Share Posted June 4, 2010 I used the plastic Cadian command powerfist on mine. I cut the scout arm off below the shoulder pad and mated the powerfist. I also rotated the wrist a bit, so the sgt could hold a meltabomb. http://farm3.static.flickr.com/2754/4461606244_9f9931c0aa_o.jpg http://farm5.static.flickr.com/4015/4461417132_c2bed6f3d9_o.jpg Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2423879 Share on other sites More sharing options...
fivepointedstar Posted June 4, 2010 Share Posted June 4, 2010 you could use one of the cadian sgt models they come in a blister pack. theres one with a pw, a one with a fist. i have used the one with the pf on my dh inquistorial storm trooper sgt. its a easy fit for scout too, and with little cutting, and mod'ing be done. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2423908 Share on other sites More sharing options...
rat of vengence Posted June 6, 2010 Share Posted June 6, 2010 A second edition powerfist works just fine. I cut it off at the top of the fist (to remove the power armour bits) and cut the scout arm to suit. http://i2.photobucket.com/albums/y26/ratofvengence/vetscout5.jpg He has been painted since, but it is the only pic I have of him. RoV Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2425687 Share on other sites More sharing options...
ArcticFox Posted June 6, 2010 Share Posted June 6, 2010 To make the joke even worse than you all seem to consider it already, in my Space Marines army, all power fists are brown in colour. But this is just because it fits the army theme :P You rock. Link to comment https://bolterandchainsword.com/topic/202928-how-can-i-get-a-power-fist-in-scouts/#findComment-2426029 Share on other sites More sharing options...
