pueriexdeus Posted May 31, 2010 Share Posted May 31, 2010 Looking at the Replacement rules on pg 66 of Apoc reloaded, and cross referencing it with the BRB pg 4&5 outlines what a unit is in a limited fashion. So the question is can an Apoc Formation be a unit for the Replacement Strategic Asset? I would think so, for example; SM Armoured Spearhead, Line Breaker Squadron, Ancient Assault Force or Deathknell Orbital trike Force, the unit operates within coherency, and have rules that are effective only if they act as a cohesive unit. All other factions, IG, Tau, Orks etc, have similar formations that could fit in this ruling. For sake of argument I think things like Battle Company's, and The Grand Warhoarde might be a bit much. Thought? Link to comment Share on other sites More sharing options...
Grey Mage Posted May 31, 2010 Share Posted May 31, 2010 No, you can only replace a unit, not a formation. A formation is made up of units, it isnt one itself. However, it can be a superheavy unit that you replace. Link to comment Share on other sites More sharing options...
pueriexdeus Posted June 1, 2010 Author Share Posted June 1, 2010 No, you can only replace a unit, not a formation. A formation is made up of units, it isnt one itself. However, it can be a superheavy unit that you replace. Reaver x2 that would work. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted June 1, 2010 Share Posted June 1, 2010 GM has the right of it, a unit is a unit, not a formation. note also that a unit does not include its dedicated transports or attached IC, both of which are seperate units. Also note that not a single formation you listed actualy "operates within coherency." As a matter of fact the only formation I can think of that quallifies as a unit is the Hive Mind Brood. Link to comment Share on other sites More sharing options...
