Mr. Bleak Posted June 1, 2010 Share Posted June 1, 2010 Hey all, I recently got some stuff from ForgeWorld, some Battle Fleet Gothic stuff, and a few of the pieces are bent. How do I go about bending them back in to shape? I think I remember something about washing them in hot soapy water and bending them back then, but I'm not sure. Please help me out! Link to comment https://bolterandchainsword.com/topic/203073-bent-forgeworld-pieces/ Share on other sites More sharing options...
Brother Nihm Posted June 1, 2010 Share Posted June 1, 2010 You remember correctly, warm water. No need for soap, unless you haven't washed them before. Washing them helps remove dust, which in turn helps your paint stay on the resin. It becomes very pliable after only 10 secs. Link to comment https://bolterandchainsword.com/topic/203073-bent-forgeworld-pieces/#findComment-2420580 Share on other sites More sharing options...
Mr. Bleak Posted June 1, 2010 Author Share Posted June 1, 2010 Thanks, that worked out great. One more question- will resin pieces bond properly if I use Games Workshop Plastic Glue, or should I use the Super Glue? Link to comment https://bolterandchainsword.com/topic/203073-bent-forgeworld-pieces/#findComment-2420598 Share on other sites More sharing options...
Rider-75 Posted June 1, 2010 Share Posted June 1, 2010 super glue. polycement will have no effect. Link to comment https://bolterandchainsword.com/topic/203073-bent-forgeworld-pieces/#findComment-2420673 Share on other sites More sharing options...
IcemanAAO Posted June 1, 2010 Share Posted June 1, 2010 another way you can do this is to use a hair dryer to heat them up, then bend them back Link to comment https://bolterandchainsword.com/topic/203073-bent-forgeworld-pieces/#findComment-2420691 Share on other sites More sharing options...
