Shadowstalker Grim Posted June 2, 2010 Share Posted June 2, 2010 Im having real trouble putting my marines from AOBR together using their push together concept......none of the marines want to hold guns, the dreadnaught cases wont fit together and the list goes on...... It seems as though the parts that are supposed to go into the holes are too big..... So i was wondering what people would suggest doing? If I am going to glue the models together will i have to remove the parts that would normally slot into place to allow for gluing them in? Any advice would be much appreciated, also i apologise if this has come up before i did try looking before i posted! Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/ Share on other sites More sharing options...
Brother Rathul Posted June 2, 2010 Share Posted June 2, 2010 I'd say just trim the eges of the pegs so they can fit into the holes better. Maybe using a file or a dremel tool could help. Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2421887 Share on other sites More sharing options...
Arnil Posted June 8, 2010 Share Posted June 8, 2010 Or just clip and file everything down and glue it as normal. Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2427989 Share on other sites More sharing options...
Vulkan 94 Posted October 11, 2010 Share Posted October 11, 2010 What i did was take a small hobby knife and cut the pegs into sharp points. This was extremely effective on the terminators and the regular boltgun hands. I ridnt have any trouble with the dread so no advive there. Hope this helps Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2533656 Share on other sites More sharing options...
Arikel Posted October 14, 2010 Share Posted October 14, 2010 I also trimmed down the posts to fit, and then just glued them in place. Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2535688 Share on other sites More sharing options...
Myxx Posted October 14, 2010 Share Posted October 14, 2010 A bunch of em, I just chopped the pegs off and glued all the body seams. Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2535747 Share on other sites More sharing options...
Wicksy Posted October 19, 2010 Share Posted October 19, 2010 I had that trouble with the bolters....i just trimmed the pegs as others have already said. Or just chop them off and glue would be the other suggestion :huh: Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2540757 Share on other sites More sharing options...
Vulkan 94 Posted October 29, 2010 Share Posted October 29, 2010 For the first guy, I just tried to jam the boltgun hand onto his arm and it ended up cracking the arm :tu: Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2548980 Share on other sites More sharing options...
Venerable Jazzman Posted October 31, 2010 Share Posted October 31, 2010 Not seen the sprue for a while, but are the arms and bodies not numbered to go together as a pair? Or are they just mix and match any arms onto any body? Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2549926 Share on other sites More sharing options...
LardO'Blood Posted November 2, 2010 Share Posted November 2, 2010 I just got slivers off the pegs with a small knife to make my tactical marines fit. As for the dreadnought I believe it is a stable enough model to just cut any pegs and glue together. Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2551484 Share on other sites More sharing options...
Vulkan 94 Posted November 3, 2010 Share Posted November 3, 2010 Not seen the sprue for a while, but are the arms and bodies not numbered to go together as a pair? Or are they just mix and match any arms onto any body? All the boltr marines and the flamer marine are mix and match, although some arms just seem to match certain bodies. The Terminators really need to cut down the pegs. The Dread is fine as is, and the captain and marines can work on their own but its better to cut the pegs. Did anyone else have uncut Termies with the front of the body sticking out reeeaally far? Link to comment https://bolterandchainsword.com/topic/203180-aobr-marines/#findComment-2552408 Share on other sites More sharing options...
