stormravens
hohoman2
I have a question;
Can the stormravens 4 bloodstrike missles all be fired in one shooting phase if its "allowed to fire all weapons"?
If thats the case imagine the alpha strike 3 stormravens all with TLLC and TML could do:
12 bloodstrike missles.
3 TLLC shots.
6 Regular missles.
I have a question;
3 TLLC shots.
6 Regular missles.
I don't have my codex at work, but what's a TML - and where do the 6 "regular" missiles come from?
I must be forgetting a weapon option.
I thought the stormraven only had access to a Twin Link Assault Cannon, Twin Linked Lascannon, Twin Linked Multi-Melta, Twin Linked Plasma Cannon, Twin Linked Heavy Bolter and Hurricane Bolter sponsons. Plus 4 Bloodstrike Missiles.
I'm sorry if that comes across as sarcastic, but it's not my intention. I actually just don't know where those bonus missiles come from.
TML is referring to Typhoon Missile Launcher I believe a 25pt upgrade to replace the stock Storm Ravens Heavy Bolters.
As far as being able to fire all 4 missiles at once I don't see why not. I see them as 4 seperate weapon systems, adn teh codex dosn't specifically say that you can't fire all of them in the same turn. That would be a pretty impressive alpha strike to be sure ;)
See? I knew I was missing an option! Thanks. :)
And yes, you can totally fire all 4 of your bloodstrike missiles assuming you've moved 6" or less.
I see a lot of people saying they move 24" and use PotMS to fire 1 weapon. Page 70 says "vehicles moving flat out may fire no weapons".
I don't have my marine codex in front of me atm. Is PotMS worded in a way that overrides the rulebook?
To answer your question rodgambit POtMS allows you to shoot one more weapon then you would normally be allowed.
Also to add to this topic i almost always run 2 stormravens at 1750 both with multi-melta and extra armour.they almost always fly 24 then assault cannon or melta stuff, normally i do this against mech armies.
Thank for the answers guys.
The 6 "regular missiles" is from the 3 Typhoon missile launchers. Sorry for confusing you.
But really, that alpha strike would really do a lot of damage. You could practically chose which armored targets you don't want to face...:P
After that use the SR to assault. Not the other way around. ;)
