Chapter master idea
Xenofei
Dante with 4xSS/TH Honour Guard (forget the Blood Champion downgrade) would hit harder than a Termy Squad without flubbing Dante's HnR, plus has the built-in Sanguinary Novitiate to give them all FC & FnP. Add a Terminator Libby with Shield, 5 Tactical Termies and a Furioso on an SR. Can you say BOOOOOOMMMMMMMMMM!!!! I knew that you could. B)
that HG is 73 points a model, w JPs. that LUDICROUS. 1 wound models? no.........way. that may be fun, but in no way is that a good idea to field.
So after much thought on the subject at work last night i ended up goin with the Grey Knight master as the stand in for my Chapter master. for a breif bit i wrote up on em (was plannin on printin it and puttin it in my codex when im done)
Uzziel of the Dual Fates, Chapter Master of the Angels Sanguine..................205 Points
------ WS BS S T W I Ld Sv
Uzziel 5 5 4 4 3 5 10 2+/4+
Wargear ------ Special Rules
●Blood oath of Terra ------●Undying Will
●Fury of Sanguine -------●Fearless
●Terminator Armor -------●Relentless
●Iron Halo --------●Independent Character
Blood oath of Terra. This is an ancient weapon passed down through the generations of Angels sanguine. This Mighty mace stands as tall as a marine and is capable of reducing most oppenents to heaps in a single blow. Its said that the weapon itself was built around a vial of sanguinius's blood which resides in the grip of this Revered relic. A disciplined mind of a Scion of Sanguinius can tap into this hidden power to unleash a blow of frightening effects.
The Blood Oath is a Master crafted (Single re-roll to hit per turn) Relic weapon that confers a +2 Strength bonus to its weilder, and can make a Coup De Grace attack that once a turn Uzziel may take a Psychic test upon wounding an enemy, If the test is passed the target is slain outright.
Fury Sanguine. Is a modified Storm bolter carried on Uzziel's armor. Using a Unique mineral found on ________(couldnt remember their home planets name). The effects of this round kept in a stable flux inside the shell give it excellent penetrating power against the effects of warp shields and force field generators as well as mundane armors.
Fury Sanguine is a Storm bolter with the following Profile. Invulnerable saves cannot be taken against its attacks.
Range Strength AP Type
24” 4 4 Assault 2.
Undying will. On a turn where Uzziel is reduced to 0 wounds instead of removing him place him on his side. Roll a D6 at the start of the next turn: On a 6 Stand Uzziel back up with 1 wound. Any other roll remove him as a casualty.
(The Above rules are for using a Grey Knight Grand master as a Chapter master of the angels sanguine. Bionics, master crafted weapon, Icon of the just, and Psycannon Bolts have been factored into his price.)
Uzziel may take a retinue of the following
Sanguine Ancients............................................................................................
.......................135 Points
------- WS BS S T W I Ld Sv
Ancient 5 4 4 4 1 4 10 2+/5+
Unit Composition
● 3 Terminators
Unit Type
● Infantry
Wargear ------ Special Rules------ Options
●Relic Blades------ ●Retinue ------- ● May add up to 6 additional ancients....42 pts each.
●Storm Bolters------- ●Fearless
●Terminator Armor------ ●Relentless
Currently workin on makin my own expanded fluff for each.
(Decided to make my accidental double post productive )
this is awesome. i felt like it was no good when i first read it, and then i started kit-bashing a GK termi with a SG death mask and a big ole weapon, and now i think its simply fantastic. im trying it out next game. for sure.
all i can say is........ thank you.
