Titan87 Posted June 7, 2010 Share Posted June 7, 2010 So I have been slowly but surely converting the new Gabriel Seth model, and On thing I needed to do was to Green stuff his chest to hide all the flesh terror Icons. As such I need a new Icon for the chest. Are their any tutorials or advice for this kind of sculpt or conversion? I did a search but came up with zilch. Link to comment https://bolterandchainsword.com/topic/203597-any-suggestions-on-making-a-chest-piece/ Share on other sites More sharing options...
Atticus_Ross Posted June 14, 2010 Share Posted June 14, 2010 You could always use a dremel and scrape it all off. Link to comment https://bolterandchainsword.com/topic/203597-any-suggestions-on-making-a-chest-piece/#findComment-2434184 Share on other sites More sharing options...
Blackwyvern Posted March 12, 2011 Share Posted March 12, 2011 I am currently converting a lone wolf from spare parts and have come across a similar problem. im no tsure if this works with metal bu tit worked with plastic. first file off any detail. then find whatever symbol you want in this case it was an aquila. cut it in to 3 roughly equal parts and glue the on tho the chest. when you do this with the wing tips wake sure that the tips are the bit that is glued. then fill in the gaps with green stuff and shape it so it looks about right. Then leave to dry and paint. voila new icon. Link to comment https://bolterandchainsword.com/topic/203597-any-suggestions-on-making-a-chest-piece/#findComment-2686843 Share on other sites More sharing options...
