calgar101 Posted June 9, 2010 Share Posted June 9, 2010 The Imperial Bastion is a great model and fantastic terrain pieceand after building one of them it got me thinking. What if you put multiple bastions together? so i propose to you how hard or easy would it be? i imagine it would be pretty straight forwwards but since i've never done it before im asking for your help! Thanks in advance. Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/ Share on other sites More sharing options...
Tanhausen Posted June 9, 2010 Share Posted June 9, 2010 What do you mean by putting them together? If you mean stacking (one on top of the other), I believe that is easily done... I have a yet to be assembled box (don't remember the name: the 2 bastions and 15 aegis line defenses), and in the pictures you can see how one of the options is just stacking them. Anyhow, I'd suggest not glueing them, so you can tailor your bastions from game to game. Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429090 Share on other sites More sharing options...
calgar101 Posted June 9, 2010 Author Share Posted June 9, 2010 Not one on top of the other but in a side by side type fashion. So extending it the sides by one, thinking about it it was bit silly to start this topic as it seems really easy.. in my head anyways :P Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429095 Share on other sites More sharing options...
Durus Posted June 9, 2010 Share Posted June 9, 2010 Here are some examples from the GW page. Side by Side WIP1 WIP2 Painted Assault on Outpost XIII. There was an article in White Dwarf in January how they made the thing. Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429101 Share on other sites More sharing options...
calgar101 Posted June 9, 2010 Author Share Posted June 9, 2010 Thanks Durus! That will give me some insight, most appreciated. Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429103 Share on other sites More sharing options...
Grumpy Tanker Posted June 9, 2010 Share Posted June 9, 2010 Check this out if you are looking to build a fortress. http://bossmansbitzbox.blogspot.com/search...20%3A00-04%3A00 Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429514 Share on other sites More sharing options...
dan_mk1 Posted June 9, 2010 Share Posted June 9, 2010 I was brought the Imperial Stronghold for Christmas and after reading the above mentioned White Dwarf wanted to try my own attempt. http://i128.photobucket.com/albums/p177/susiemk1/IMG_1586.jpg http://i128.photobucket.com/albums/p177/susiemk1/IMG_1597.jpg Assembling it wasn't too hard just have to trim a couple of the ends so they fit flush. Good luck with your project :D Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429597 Share on other sites More sharing options...
Tanhausen Posted June 9, 2010 Share Posted June 9, 2010 AWESOME scenary! The elevated base is a great idea and the aquila doors look magnific! What did you use for the big panels? *** still trying to close his mouth *** Seriously, very very nice! Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429628 Share on other sites More sharing options...
calgar101 Posted June 9, 2010 Author Share Posted June 9, 2010 Thanks for the site Grumpy will save to faves and read tomorrow! WOW Dan that is plain awesome my friend! If i do one as half as good as that i'd be pleased! Thanks guys! Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2429809 Share on other sites More sharing options...
THE GHOMA Posted June 11, 2010 Share Posted June 11, 2010 buildng them side by side is relatively easy. All you need to do is assemble the model, except with one side missing, then do the same with the other bastion. Push the two missing sides together and you should be able to get a double bastion. Some conversion work may be needed to fix the gap on the roof area though Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2431668 Share on other sites More sharing options...
Marshal Rohr Posted June 12, 2010 Share Posted June 12, 2010 I was brought the Imperial Stronghold for Christmas and after reading the above mentioned White Dwarf wanted to try my own attempt. http://i128.photobucket.com/albums/p177/susiemk1/IMG_1586.jpg http://i128.photobucket.com/albums/p177/susiemk1/IMG_1597.jpg Assembling it wasn't too hard just have to trim a couple of the ends so they fit flush. Good luck with your project :P YOU!!! Where is your Templar blog? :ph34r: Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2432033 Share on other sites More sharing options...
spu00sed Posted June 12, 2010 Share Posted June 12, 2010 I've built a large fortress with several sets. If you are building simple line or square buildings then it is easy. However you need to think about extra supports and filling in gaps if you go for something more complex, such as a T http://i22.photobucket.com/albums/b337/Sdimbylow/Planet%20strike/Fortress1.jpg http://i22.photobucket.com/albums/b337/Sdimbylow/Planet%20strike/Fortress2.jpg Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2432615 Share on other sites More sharing options...
Cam2Designs Posted June 12, 2010 Share Posted June 12, 2010 http://www.fortheemperor.com/forum2/viewto...?f=16&t=150 This is a creation of my friend Robert. I've defended it in battle and it rocks! Link to comment https://bolterandchainsword.com/topic/203747-imperial-bastions/#findComment-2432632 Share on other sites More sharing options...
