Fixing bent swords... carefully!
Heat the pewter with boiling water (submerge for a minute or two) - it should become fairly pliable. Be careful of 2 things though, 1) don't burn yourself with the water 2)don't mar the surface of the sword - if you use pliers or something similar, pad it with a bit of paper towel.
Hope that helps.
