Chengar Qordath Posted June 12, 2010 Share Posted June 12, 2010 So, I was reading through the Daemonhunters codex, and there is nothing in the rules that says Grey Knight Terminators count as two models for the purposes of being transported (instead, this rule is reflected in the entry for GK Land Raiders). Would this mean that, by RAW, a GKT only takes up a single slot in any non-GKLR transport they are mounted in? Link to comment Share on other sites More sharing options...
Hellios Posted June 12, 2010 Share Posted June 12, 2010 So, I was reading through the Daemonhunters codex, and there is nothing in the rules that says Grey Knight Terminators count as two models for the purposes of being transported (instead, this rule is reflected in the entry for GK Land Raiders). Would this mean that, by RAW, a GKT only takes up a single slot in any non-GKLR transport they are mounted in? If we are not talking about Apoc then older dexs often have dedicated transports which you can't go in anyway... Marine Rhinos state models in terminator can't fit in them... I think GW FAQ'ed that they can't go in Valkyries but I guess potentially you might be able to use chimeras or other marines Land Raiders... although don't expect people to let you do it RAW or otherwise... Link to comment Share on other sites More sharing options...
Marshal Wilhelm Posted June 12, 2010 Share Posted June 12, 2010 So, I was reading through the Daemonhunters codex, and there is nothing in the rules that says Grey Knight Terminators count as two models for the purposes of being transported (instead, this rule is reflected in the entry for GK Land Raiders). Would this mean that, by RAW, a GKT only takes up a single slot in any non-GKLR transport they are mounted in? As Helios said, that would be covered in the allies Codex for transports. For their Terminators/Ogryns etc. If you find a loop hole in that, tell us and we'll RAWhammer it out. I can guarantee you'll make your foe sour ~ :P , even if it is a legitimate loop hole. Link to comment Share on other sites More sharing options...
Grey Mage Posted June 12, 2010 Share Posted June 12, 2010 The most common exploit for this is using an Inquisitorial Valkyrie to carry around some GKTDA... but its a good way to get IA kicked from your club in a hurry. Link to comment Share on other sites More sharing options...
Chengar Qordath Posted June 12, 2010 Author Share Posted June 12, 2010 Well, I did assume that, even if it is RAW, everyone will hate you for playing it that way; it is a case where RAW is stomping on the game's internal logic, unit consistency, and in all likelihood the original intent of codex writers. I suppose it is just another example of the weirdness that can result from allying units from a 3rd edition codex into a 5th edition army. Link to comment Share on other sites More sharing options...
Gentlemanloser Posted June 14, 2010 Share Posted June 14, 2010 It's going to be interesting with Spearhead and GKT in Chimeras purchased with Armoured Spearhead. :D Link to comment Share on other sites More sharing options...
