Roland Durendal Posted June 16, 2010 Share Posted June 16, 2010 Back in the day the assault cannon, HB was popular but with 5th edition and higher costs this configuration is pretty much gone. Landspeeders should always be moving more the 6" to ensure that they are not hit on 4+ in CC and should always be taking advantage of cover for a 4+ cover save. Occasionally the flat out move is handy too.I also believe that you should always have 2 weapons on the speeder. My favourite combos are Multi Melta/ Heavy Flamer (Great tank hunter and nice redundant weapon at a nice price) and the Typhoon/ HB (Great for tank hunting with the ML's or punishing infantry with the HB and frag missiles. This combo is a bit more expensive but has the advantage of superior range.) QFT. THough I play wolves, when I run speeders I usually use one of these two set ups he listed above, depending on mission: Close Range Anti-Tank (and if needed horde control) - HF/MM Long Range Anti-Tank - HB/TML If I use a HB/TML he'll usually float around my backfield with my Long Fangs and pour out krak missiles. At 2000 points, I can effectively put out 12 krak missiles a turn aimed at up to 5 different targets. It's fire saturation. Link to comment https://bolterandchainsword.com/topic/204152-landspeeder-configurations/page/2/#findComment-2436297 Share on other sites More sharing options...
Wildfire Posted June 16, 2010 Share Posted June 16, 2010 If you're intending to use them to screen your Stormraven, I think you should take a look at how you're going to use that unit. If you're going to rush in and unload an assualt squad, I think multi-meltas is a must in order to crack open transports so that assualt squad can do it's job. If you're going to use it as a mobile gunship, you should look at longer ranged options. Link to comment https://bolterandchainsword.com/topic/204152-landspeeder-configurations/page/2/#findComment-2436310 Share on other sites More sharing options...
Lynnean Posted June 16, 2010 Share Posted June 16, 2010 i run a MM/TML combo. MM for when a tank is annoying me, TML for long range. Link to comment https://bolterandchainsword.com/topic/204152-landspeeder-configurations/page/2/#findComment-2436449 Share on other sites More sharing options...
Fropopo Posted June 18, 2010 Share Posted June 18, 2010 Hi, I'm a beginner and I'm planning to use LS in my 1500 points army list. I can only spend 140 points in them so there is not much choice. What would you suggest, 2x MM+HF; 2x MM+HB or one of each? I would use them separately as I'm not taking any more fast attack. I leave here the list so you experienced players can evaluate everything: Reclusiarch (130) B) RAS, 2x MG, PF (235) RAS, 2x MG, PF (235) Tac squad, ML, Flamer, Rhino (220) Death company, PF, IP, PW, Dakka Razorback (245) :) LS, MM, ¿? LS, MM, ¿? Vindicator Any suggestion, change i should make or whatever? Do you think this will be a fun list to play? Thanks a lot! Link to comment https://bolterandchainsword.com/topic/204152-landspeeder-configurations/page/2/#findComment-2439002 Share on other sites More sharing options...
daboarder Posted June 18, 2010 Share Posted June 18, 2010 if you're limited pointwise I'd go the mm/hf. Link to comment https://bolterandchainsword.com/topic/204152-landspeeder-configurations/page/2/#findComment-2439035 Share on other sites More sharing options...
Brother_Dan'l Posted June 18, 2010 Share Posted June 18, 2010 The MM/HF used to be my favorite but these days (if I actually use a Speeder) I'm running mostly HB/TML. I can engage any target type I want without getting in range of any S4 basic weapons they may have. So moving 12" and laying a Heavy Bolter and a pair of Frag Missiles into an infantry target or a pair of Krak Missiles into armored targets is very satisfying. Link to comment https://bolterandchainsword.com/topic/204152-landspeeder-configurations/page/2/#findComment-2439066 Share on other sites More sharing options...
Lithanial Posted June 18, 2010 Author Share Posted June 18, 2010 You have a fair bit of anti-tank but not much shooting so i would probably go 1 with HB/TML and a second with just HB in one squadron since you are tight on points. 6 HB rounds and 2 missiles is not too shabby plus you can load up the cheaper plain HB speeder with the damaging hits. Link to comment https://bolterandchainsword.com/topic/204152-landspeeder-configurations/page/2/#findComment-2439103 Share on other sites More sharing options...
